2006 vert outside temp reading always off
Old 10-02-2010, 12:45 PM
dlnc6
1st Gear
dlnc6's Avatar
Default 2006 vert outside temp reading always off
how cn i trouble shoot the problem of my outside temp reading is always off?
Old 10-02-2010, 12:48 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
2006 owner's manual, page 3-29.
If the outside temperature goes up, the displayed
temperature will not change until:
• The vehicle’s speed is above 10 mph (16 km/h) for
five minutes.
• The vehicle’s speed is above 32 mph (52 km/h) for
two and a half minutes.
These delays prevent false readings. If the temperature
goes down, the outside temperature will be shown
when you start the vehicle. If it has been turned off for
less than three hours, the temperature will be recalled
from the previous vehicle operation.
Also see this thread for instructions on how to get it to show the current temperature immediately:
http://forums.corvetteforum.com/c6-c...s-way-off.html
Old 10-02-2010, 06:51 PM
haljensen
haljensen's Avatar
Always off compared to what? Temperatures vary widely over a very short distance. The two main weather reporting stations in Austin, TX are only 10 miles apart but the high (and/or low) temp will vary as much as 12°.
If you.ve ever ridden a motorcycle you have to have noticed the temp difference when you ride through a low spot in the road, just 20 ft. in elevation can make a big difference in temp.
Don't forget that your temp sensor is down low in the front of the car, it may be getting road surface temps instead of air temps.
To 2006 vert outside temp reading always off
Quick Reply: 2006 vert outside temp reading always off
