Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Cleaning and Detailing
- How to restore your headlights
Step by step instructions for do-it-yourselfers.
No Low Beam Headlights
#201
Ok, call me stupid (no, please don't) but why is everyone following the original wire path? It seems to me that GM used that wire path to avoid the holes that later became heat rivets. Now that we aren't trying to delaminate the boards, we could just go straight out to the edge and down to the other end while only making two bends total. Am I missing something?
I took mine apart last night, found "the break" (same spot) and will be rewiring tonight.
Original side:
Back(up) side
#202
Having taken a picture of the fuse box prior to dissection made reassembly super fast and easy. reinstalling in the car - 2 minutes once I realized I don't have to re-connect the blocks underneath (the screws pull them together for you). Now, finding what I did with the keyfob took a half hour. I had dropped it in the street. It's a miracle I found it. And now the moment you've all been waiting for....
#203
2005 here and think I have this same problem... debating if I am going to try and re-wire or just replace the fuse box. I would think the other wires would be next in line to break, but I don't see any complaints on here about the others which does make it seem like the one bend in particular is the issue.
#204
The write up simply says "replace the wire." I'm not a part time electrical engineer like you gurus, does it need to be soldered on? If not, how does it connect?
#205
Let's remember also that this type of fuse box is probably used in all GM cars, so this is an unusual problem as we have not heard of this type of issue being a huge problem in other cars. The problem is likely limited to the one wire bend rather than the overall design of the box.
#206
Once the box is open, you will see that those wires are just squeezed between the pins on the connector. I think that "swedged" is the right term for it. There is no soldering, although it could be done to add to the repair. Many here have added another wire between the two end points as a backup...seems like a good idea to me. I think the basic weakness is that the wire is bent too tightly at that point where it ends up breaking. It is undoubtedly made by machine, so the consistency of the problem at that one point would mean that the machine is doing something slightly wrong at that one bend.
#207
If anyone has already replaced their fuse box, or is planning to, I'd be happy to give you $50 for your old bad one.
#208
C5forFun (10-31-2016)
#209
• 111,889 2005-07 Chevy Corvettes for a potential loss of low-beam headlamp function.
This came out in a report today 5-15-2014 in Automotive News to Dealerships. They say there is a major recall on many Chevy models but for the C6 Corvette this is the only mention of any problems:
GM said a problem with the wiring to the low-beam headlamp could cause it to stop working intermittently. GM said it is aware of "several hundred complaints" but no crashes related to the flaw.
GM said 2008-13 Corvettes that have the same problem with the low beams will be fixed under a customer satisfaction program.
#212
Check out the link below.
They speak of recalling the 2005-07 Corvette.
About 3/4 of the page down.
http://news.msn.com/us/gm-recalls-27...on-record-pace
Here's the same from USA Today:
http://www.usatoday.com/story/money/...ipers/9118137/
#216
Did you see this?
— Nearly 112,000 Chevy Corvettes from 2005 through 2007 because they can lose low-beam headlights. GM says when the engine is warm, an electrical housing can expand and bend a wire, causing it to fracture. GM will also repair Corvettes from 2008 through 2013 if owners have the problem.
#220
I'll bet they replace it with a new one...having a mechanic rewire is probably more expensive and the quality of the repair can't be verified to be consistent across all cars.
