Tunnel Plate Bolt Torque?
Received 2,047 Likes
St. Jude Donor '13
I've seen several comments about bolts in the tunnel plate coming loose (or were never tightened at the factory), what's the correct torque on a 2009 base Coupe Z51 A6 ?
Thanks!
Thanks!
I copied this off elite engineerings website
Starting at the center of the tunnel and working side to side and then front to
back, torque the screws to 89 in.- lbs. in. (yes, that's 89 Inch-Pounds or 7.4
Foot-Pounds). Don't over-torque as the screw heads are likely to break off
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,813 Likes
2015 C7 of the Year Finalist
Also, when you are done? Do it again and recheck the torque. The first ones will be loose.
Elmer
Elmer
I checked mine last Sunday, all were loose, I snugged them all up with a 1/4" ratchet by feel. Most took 1/2 turn, a few took more, one took two turns! I was amazed how loose they were. My car didn't make any noises but after reading about this I checked anyway. I don't know how you are supposed to torque them upside down, much less with that small of actual torque. Snug them up and check them when you change your oil.
Told you those little farts would be loose!
Elmer
Elmer
