Water Wetter
Pretty mixed results, works for some not for others. If you care to do an Advanced Search on "Water Wetter" in C6 General and Tech you will get a big list of discussions. Here are just (3) I grabbed:
http://forums.corvetteforum.com/c6-c...r-results.html
http://forums.corvetteforum.com/c6-c...er-wetter.html
http://forums.corvetteforum.com/c6-c...-it-works.html
Water Wetter originally was a substitute for antifreeze. It would help stop corrosion and lubricate the water pump when used with plain water. Adding it to Dexcool might be a problem, Dexcool doesn't play well with others.
Two bottles in my 2008 C6 lowered the water temp about 5 degrees F. No issues with the Dexcool. I now use it in several vehicles and my tractor. As stated above, works best with just plain water.
Just curious why do you want lower temps? Unless you race the car alot , day to day driving it's not gonna make that big a difference. Sure, when the car is cooler its gonna run a bit quicker and timing is not pulled, but again for daily use GM designed the car to run the way it is with the Dexcool.
This reminds me of all the people running a stock motor with a 160 T-stat on a stock tune=waste of time
