Follow up on steep driveway.. NEED HELP/IDEAS?
I posted a while ago i had trouble getting into my garage because its in a steep driveway.. i finaly got some pics of the actual problem... anyone have any ideas... some1 mentioned girotsgarage curb bridge
[IMG]<a href="http://s830.photobucket.com/albums/zz228/AMxMAK/?action=view¤t=IMG00005-20100825-1559.jpg" target="_blank"><img src="http://i830.photobucket.com/albums/zz228/AMxMAK/IMG00005-20100825-1559.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s830.photobucket.com/albums/zz228/AMxMAK/?action=view¤t=IMG00004-20100825-1559.jpg" target="_blank"><img src="http://i830.photobucket.com/albums/zz228/AMxMAK/IMG00004-20100825-1559.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s830.photobucket.com/albums/zz228/AMxMAK/?action=view¤t=IMG00003-20100825-1559.jpg" target="_blank"><img src="http://i830.photobucket.com/albums/zz228/AMxMAK/IMG00003-20100825-1559.jpg" border="0" alt="Photobucket"></a>[/IMG]
You'll need some sort of extension whether permanent or some thing you throw down when going in and out. Cheap solution get some 1x8s build something. Not much you can do unless you want to spend big$$ re doing the concrete. I remember reading about a company that made ramps for driveway entrances but I'll have to Google it.
I am still a newbee, but I have seen this question posted several times. As was stated above, there is a company that makes a filler if you will that bridges the angle to make it less steep. If I remember they are not cheap, but neither is a new front bumper.
Maybe try a 2 x 10 or 2 x 12 to bridge that steep angle and maybe by changing the angle that will make the difference.
Former Vendor
West Coast Corvettes
Thes xe should do the trick. If you have any questions let me know 888-737-8388 x214
http://www.westcoastcorvette.com/p-2...-3-pc-set.aspx
Get some pressure treated lumber and plywood and build your self a nice looking ramp. If you use 2x6 stock with 3/4" plywood (all pressure treated so it doesn't rot) this will be more then enough to support your car and you can build it out as far as you need.
You have such a steep incline that even a filler ramp like the one posted I fear will not do the trick.
Just my 2 cents
Just my 2 cents
Received 1,101 Likes
May not work for you with space limitation but try approach at 45 degree angle. That technique works best at the street end in places where you would otherwise bottom out going straight in/out.
There is a cheap solution. Drill holes in the bottom of that conctrete slab, horizontally every few feet, pump sand into those holes and it will lift it high enough that the slope will not exist. Cost...less than $300.
Sure, that slab will no longer be flush against the driveway, but a couple of inches is not that much.
shipping question
price (around $375). But when I tried to order a set, I was forced
to select a shipping method. However, selecting the slowest method
resulted in an additional $230 (approx) to the bill. So, is shipping
included in the $375 price, or is it an additional charge. Thanks.
These ramps look like just the thing I need.
Former Vendor
OK, I went to the site and it says that shipping is included in the
