Advice request on Creaking Roof
I had exactly the same problem, sprayed pure silicon lubrcant on the weatherstrip seals surfaces and Voila! the noise left and never came back. It was actually an embarrassment prior to the silicone.
They sell it at all auto parts.
I took my 2005 into the dealer for the top and steering column recall - explained to him my top was very quiet and was no problem. The service writer said that GM was replacing all the tops as part of the recall and advised that I change mine out also while the did the column fix. Well, the new top creaks and pops like crazy over uneven roads and while turning hard. It's really annoying but I don't have time to go back and forth to the dealer messing with the problem. I guess I'll try the silicone lube and hope for the best. I really would like to have my old "defective" top back.
Received 2,060 Likes
St. Jude Donor '13
No personal experience with the spray.
St. Jude Donor '13
There is a lot of talk about this topic. I had horrible problems with the noisy roof in my '09 C6 too. Dealer was no help and the car has supposedly the latest latches, etc. I was at the end of my rope when I accidentally fixed it.
After all the other cures were tried (lube, adjustments, etc.) I was loosening the latches as I drove (slowly!) trying to isolate the culprit. The noise stopped right away!! Apparently, the top settled properly or better. After I re-locked the latches it never made noise again
I just bought a glass top off another member and it makes a little noise every now and then but it's no big deal.
You might try what I did and see if it helps. As for the charges, I think it's wrong to charge you money for a no good fix
But, glad it worked for you!
