loose backup light
Supporting Vendor
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
2 screws on top of light and tabs on the bottom. May have to unscrew the housing, stick the tabs in then reinsert screws. You can crawl under car or may can reach them through the tail lights.
Stick your head up between the mufflers. Well kind of, you can get a glimpse into there though.
Tabs on bottom of lens slip into slots. Not a snug fit so it can wiggle a bit. Screws on top of lens.
St. Jude Partner since 89
A friend of mines was loose too on his 08 Z06 and come to find out the tabs were broken off. This sounds crazy but I duct taped it when we had it up in the air putting headers on over a year ago and it's solid as a rock. That's a good fix if that's your issue and you like free.
yep, got the same problem. Bought the car new and it is has always been loose at the bottom. I just left it alone since it doesn't seem to cause a problem. You would never know it unless you push on it.
Same problem on mine on the driver side. The two little tabs are broken on the bottom.
Rolled up some good sticky duct tape and placed it on the area where it should sit at and seems to be holding pretty good still... No reason to push on it a lot and am careful when washing. So far so good..
