Madvette's solution to annoying seatbelt flapping!
#41
Former Vendor
The Belt Clip for C6 Corvette
MadVette Motorsports is proud to introduce our all new accessory for the C6 Corvette: the patent-pending Belt Clip.
Does your passenger side seat-belt flap annoyingly in the wind when your windows are down in your C6 Corvette?
Does the sound get worse when the top is off on your Coupe, or with the top down on your Convertible? If so, then we have the perfect solution to relieve your driving headache.
The Belt Clip is made of durable ABS plastic. It matches your interior side B-pillar panel perfectly!!
Easy to install, almost invisible to the eye, and the FIRST & ONLY product of it's kind.
MadVette Motorsports is proud to bring it to you exclusively!!!
Get one for your C6 Coupe, Convertible, ZR1 today!!
It is the perfect compliment to our popular C6 VetteBin & Partition combo in effectively reducing wind noise and turbulence in your cabin, allowing you to fully enjoy the pleasures of driving America's sports car once again!!
GM should have made this, but they didn't... so MadVette Motorsports has the perfect solution for your C6!!
At only $7.00 ea., the Belt Clip is both efficient and inexpensive.
CLICK HERE TO ORDER!!
#42
I got one, received it a few weeks ago, but I don't really know how to get it into place... How do you get it under the plastic???? I can't really "pick up" mine...
#43
Former Vendor
Using one of the above post's photos as a guide.....just work your finger under the trim piece where it meets the carpet and pull out enough to slip the back side of the belt clip behind the trim piece.
Call me at the shop if you any problems....615-907-8125.
Tim
#45
Former Vendor
