Sun visor mirror hinge broken
The hinge on the mirror that is mounted on the passenger sun visor (on my C6) is broken. Is it necessary to replace the entire sun visor, or can the vanity mirror assembly be replaced? Is GM the only/best source?
The visor has to be replaced. If your car is out of warranty It's an expensive job. It's hard to believe gm is still using plastic hinged door. I,m on my 3rd one on my'08.
Same thing happened here. But, the car was still under warranty. Luckily for me NO questions were asked and it was taken care of.
Good luck. Little things can ruin a day.
Premium Supporting Vendor
Yes, unfortunately you have to purchase a new one. If you need assistance with new, please let me know as I would be happy at the opportunity to earn your business.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Received 2,051 Likes
St. Jude Donor '13
Somebody once posted that he put some "oil" on his hinges and they deteriorated. That sounds weird, I use a tiny dab of Dielectric Silicone Grease with no problems.
C6 Sun visor with vanity mirror
My driver side is broken also.
Kinda like that fuse block cover that was not available til everyone started having broken hinges, now there available. Maybe someone will get the idea that these should be available too. Funny how the market works, build it and they will purchase!
Mine just broke off today. Did you guys have any issues with it draining your battery? I don't need that issue as I have an 05 and finally got rid of that stupid priority start that was making things even worse. I just don't want to deal with a dead battery from this cheap visor.
Tolero Apto Victum
Mine have also broke.
I did a repair using velcro cut into small pieces on the corners.
Then I cut small strips mount them next to to broken hinge.
This works fine. You just have to pull the cover a little to get the velcro to release at the corners. At least I can still have the lights work and didn't have to spend 250 for 2 complete visors.
Anyone else have another method please let me know.
Dusty
Dusty
