05 Vette raise front end/spacers?
I would really like to raise the front of my Vette about an inch. Its an 05 C6 coupe. Can I use spring spacers to do this safely and without any problems?. Can I use rubber spacers, or does anyone suggest any other type of spacer and where to purchase. There are a lot of them on the net but I also don't want to create any other issues by doing this. Any suggestions?. PS. Will the car overheat if I remove the front spoiler which as you all know scrapes everything. Thanks. ggolds5@aol.com
The Forum consensus is that yes the car will run hotter. Actual overheating may come down to the climate you're in.
I know it's painful to hear the thing scrape, but it is after all, almost a sacrificial piece (3 pieces) and it isn't very expensive to replace.
My vote is, don't raise your front end.
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
If you really want to raise it up, adjust the ride height bolts first before doing any "spacer" things.
Yeah, just use the bolts. You can get 3/4" higher. I guess you'd want to raise the rear to match. Car & Driver raised the car they drove to Alaska by the bolt method. Since this is an adjustment device that comes with the stock vehicle I doubt there would be any cooling problems as a result.
If you do decide to go this route take some before and after pics and post them.
Retired & lovin' it!
Why in the world would you want to RAISE the Vette, especially only in the front? The bit of air dam scrapping we all deal with going over speed bumps or steep driveways is nothing compared to spoiling the look of the C6. Don't do it!
Was the car lowered before? If so get some stock bolts and put it back where it belongs. Go and measure some new ones at a dealership. Make sure you have the correct wheel / tires also. If the car was used you have no idea what the prior owners did to it. Mine scrapes a little on STEEP inclines, you grimace and then move on. No real damage to the air dam, its flexible, gets a little scraped up is all. I wouldn't take it off, it helps with cooling.
Then again Air ride! Raise it up to clear the drive way and then drop it until you get sparks!
CF Senior Member
If all you're doing is scraping the front diffuser I would not raise the car. It may scrape on occasion but I can't imagine it scrapes on "everything." As mentioned, its designed to withstand some scraping. I've heard of a very few people who've reduced or removed the diffuser. The one guy who removed it claimed to have no ill results, however, the fact remains its an integral part of the cooling system. Your call.
Raising the car may not create a problem with typical street driving but its certainly the opposite of what someone would do who's trying to improve the 'performance' of the car. There could also be adverse affects on the suspension. There's no guaranty your car was setup perfectly from the factory. If you do start messing with the setup I'd make the effort to do it right. There are specific procedures to follow, measurements to take and re-take, etc. to insure the car is 'balanced' properly.
Lastly and of less importance, raising the car will definitely not enhance its appearance. Good luck whatever you decide to do.
Raise the front end? Now there is something you don't here very often....err....ever! I have trimmed my front spoiler 3\4" and never had any issues, not sure taking the whole thing off would be ideal, but maybe some others have done it with good results. The spoiler is made to scrape, 459,000 other vette owners live with it, why don't you? Your car will look ridiculous raised even one inch.
Perhaps he wants to raise car so he won't have to worry about curbs when parking along with all the other problems that come with a car that's low to the ground i.e. rock chips etc.
At the current height cement curbs do major damage to this car.
I removed the whole thing
I removed my rubber spoiler quite a while ago. It has caused no issues at all with overheating. I live in Austin, Texas where it is often 100 degrees or more. The car is my daily driver. I'm happy not having to hear the scraping anymore.
I raised mine to 27" measured at the center of front wheel, bottom of wheel opening to ground. Done by my tire dealer by using the stock bolts. Did not want to push the limit of the amount of threads that extend above the leaf spring. This threw the alignment way out per the alignment guy, which of course he corrected ... just FYI ....
