Here's A Tip For You
Location: Lower, Slower Delaware, formerly from Mobtown, MD (Baltimore)
Put the new GS in the lift yesterday to detail, pressed the toggle switch to on/accs to release the shifter (A6) to put in neutral to spin the rear wheels for cleaning. Well dummy me, let the lift down for the evening and called it a day.
Put it back up today to finish waxing, etc., couldn't get the door open with the FOB, nothing's working, startin' to panic now, WTF.
Used the key on the FOB to open trunk lid, pulled on the door release to enter, and lo and behold, left the shifter in neutral, and of course the accessories mode was still on, which of course drained the battery. Who knows what the hell else is on when the accs toggle is on.
Well of course the battery is dead, on slow charge now. Gawd, I hate getting old. :o
Hmmm...I know mine shuts Acc mode off after about 20 mins or so. Maybe a difference between Auto and MN6? Or did you actually have it in run/engine off mode?
Started up, everything seems to work except the windows not shutting all the way up. You know how the window opens and closes a tad when opening and shutting the door, that's not working now. Will I have to re-program something to get that back to normal?
Thanks for any help.
Probably. C5's, I know my way around a little bit, new to C6's.
Get in and close the window, keep the switch up for 3 sec. after it reaches the top. Let go, then hold the switch up for another 3 sec. and that should be it.
It wasn't accessory mode that did you in, it was neutral. The car needs to see park to shut the systems down.
Nice to know there are some smart people on here as opposed to this big dummy (me).
FYI, you also shortened the battery life by about 50%. Starter batteries are made to take shallow discharges, not deep discharges like this.
When it fails, don't blame the battery.
Can you tell I work for a battery manufacturer....
Now I'm paranoid, thinking I'm going to have to replace it any time now.
Thanks for the info.
Whew,thought you were gonna say it rolled off the lift and crashed into the dinning room!!!Dont sweat the battery,it was gonna die soon anyway.
So, an A6 C6 should not be parked in neutral... even with ACC off, I'm guessing the system will never fully go to sleep. And the battery will drain more quickly.
Sorry for the slight OT
Received 2,054 Likes
St. Jude Donor '13
Batteries have a lot of individual variation. We see people here who flatten the battery once and it never really holds a good charge after that. But we also see cars sitting at the dealership where the battery goes dead once a month until the car finally gets sold, battery works for years after that.
I've had several batteries that went complately flat a time or two but lasted a good while afterward.
If I were the OP, I'd charge it up and see what happens. The only issue would be if your life conditions would make a dead battery somewhere, dangerous. The battery is covered by the 3/36 warranty.
Good luck...
Good luck...
St. Jude Donor '13
There is a load test that is better than a simple voltage test, but nothing seems to be accurate every time.
