Corvettes DNF at Le Mans
Moderator
Received 3,592 Likes
As far as the engines going bad, it might be not using E85 since that is what they were designed to run on.
If someone looks at the preferred racing line for Le Mans they will find the 64 was on it and leading Davidson into the corner. The racing line then switched sides of the track for the next corner. When Collard looked inside there is Davidson.
At that point he had two choices. One was to run into Davidson taking both cars out, 2nd was to run through the "clak" which is basically old rubber pebbles on the road. That quickly reduced his traction and forced him off the track. Davidson raced GT cars before so he knows how much less downforce the GT cars have compared to the LMP cars. Difference is between night and day.
I watched the race and Davidson was passing cars using the shoulder right before the crash, which it is illegal to go outside the white lines. The announcers were leaning on Davidson pretty good and I think one of them was also British. Actually they crticized Peugeot's tactics from the beginning of the race. Davidson's car had around 20 minutes more time in the pits compared to the Audi, mostly to fix their mistakes.
Wurz was a lot better of a driver compared to Davidson. Davidson even got airborne when he was coming into the pit for the final time.
I was worried about Corvette when they did a nice story on the Corvette Racing team in the pits earlier in the morning. Then the 63's engine failed and not much longer 64 was in the barrier. The repair on the 64 was AMAZING. Much credit has got to be given to the Corvette Racing team. Of course the engine failed later on. It is hard to say if it is part of the accident or not. I don't think so but the oil system on the GT2 is in the trunk. Peugeot's and Corvette's reaction to the accident was very different. Corvette's was very political while Peugeot's, especially Davidson's was as if Corvette deserved it. Davidson's reaction and his other race issues lead me to believe it was his fault. Audi's leader chewed up a BMW's pit crew for their "mistake" which IMO was not a mistake.
Well karma came around and Peugeot's remaining cars failed before the race ended. Bordais didn't even get to see a green light since his Peugeot broke on the first stint.
Davidson should have been penalized for his passing on the shoulder at least and his car should have been required to stay in the pits until they fixed a body panel (that was broke and not the Corvette's fault). That is another one of those rules that the stewards tended to overlook with Peugeot.
Sometimes an accident is not as it seems and something that occured laps earlier usually contribute to the accident (bad pit stop, agressive driving, prior mistake, etc).
The 64 vette had a 1" hole in the oil sump as a result of the crash...then he drove back to the pits and the sump was empty...not clear if any oil was still in the lines or not...
Is anyone disappointed at the coverage provided to GT1 and GT2 by SPEED? Seems to me they focus on the P1 and P2 classes and only comment on the GT classes when they have to. Reminds me of a 12 year old boy lusting after his first french kiss. Doug Fehan mentioned this during the C5/C6 Bash. Apparently, the team has been apprised of the lack of GT class coverage. It's getting hard for me to watch the constant dribble about Audi's and Peugeots.
IMUO
IMUO
IMUO
IMUO
IMUO
IMUO
Is anyone disappointed at the coverage provided to GT1 and GT2 by SPEED? Seems to me they focus on the P1 and P2 classes and only comment on the GT classes when they have to. Doug Fehan mentioned this during the C5/C6 Bash. Apparently, the team has been apprised of the lack of GT class coverage. It's getting hard for me to watch the constant dribble about Audi's and Peugeots. IMUO
What I would like to see is the program called "Corvettes at Le Mans" and only focus on that team. Not going to happen, though.
-Clark
Received 1,409 Likes
2017 C7 of the Year Finalist
St. Jude Contributor
I.............................
"The crash" was the Corvette's fault, not the Peugeot. No contact was made. At first viewing, it looks as though the Peugeot is losing his inside line and pushing the Corvette to the outside and into the rough stuff near the edge, causing the rear to step out.
My analysis is that it was a miscommunication on both drivers' parts...but the C6R had the right of way and gave it up; The Corvettes' mistake was that he altered his line to make room for the Peugeot on the inside as the Peugeot was expecting to pass on the outside, then dropped inside as he saw the Vette moving away from the apex. That's just part of developing "racecraft" or technique.
Crazy and stupid, the Puegot should have been waiting for his opportunity later down the track. It was out right foolish, especially with a car as fast as his who would have easily been able to make the pass only seconds later down track.....
Maybe you'd like to see it again....
Click ===> HERE
Moderator
IMUO
IMUO
#33
Moderator
This incident was clearly Anthony Davidson's (Peugeot) fault. In pre-race drivers meetings it was clearly stated that the slower cars continue with their normal line and the faster car find his way around. This happened in the Esses which basically turned this particular portion of the track into a double apex left hander. The Corvette never altered his route and the Peugeot attempet to pass in that very short area between the two apexes.
Click ===> HERE
Click ===> HERE
#36
Well up till the 'incident' the Corvette team was doing a great job making miles and staying out of the way of rookies and reckless wild guys. It looked like the crew worked their *** off fixing the 64! Couldn't ask for more. I'm sure they'll find and fix the problems on the 63.
Didn't they win 7 of 9 years or something like that? Can't wait till the next time!
#37
I agree about seeing more of the GT classes - although I recognize that SPEED does not control the feed. However, someone on TV made the point that the Le Mans series contributes more to advances in road cars than any other series. If so, I imagine that statement is based on road cars derivatives in the race rather than the esoteric prototypes. I wonder if Formula 1 contributes just as much to actual road cars as does the prototype classes.
#39
Moderator
#40
Moderator
