rust
It is in fact normal.The rotors are exposed to the elements.They will also get that way pretty much everytime you wash the car!Goes away after driving 10 minutes or so and hitting the brakes a few times.There are treatments out there for rotors.
It's a fact.
It's a fact. For $1400 you could replace them with Baer Eradispeed rotors with anodized aluminum centers. This will minimize rust at the hub, but the rotors themselves will still be iron and will rust when exposed to moisture.
Received 2,051 Likes
St. Jude Donor '13
The more often you drive it, the quicker the rust disappears.
Drive that puppy and enjoy!
This is normal. I also didn't like it so I cleaned up the rust on the rotor hats and then put VHT paint on them. I did this when I was painting the calipers. I don't know how long it will hold up but for now it looks better.
