Tech 2 scanner
Cruising
Tech 2 scanner
Can anyone tell me what the polarity of the center pin is on the AC/DC power supply for the Tech 2? Also has anyone found a less expensive alternative to the OEM power supply?
On my Bosch Tech 2, the inner pin is positive @ 12v/1.5amps. (There is also a Tech 2 made by OTC. I do not know about that one.)
I assume you have the DLC cable and all you need is the power supply.
You should be able to use any 12v 1.5amp power supply with the correct pin. You can get pin adapters at Radio Shack.
