Steering column lock
It only effects the '05 with the manual transmission. If you have a manual then you should get the bypass if you are having the problem. More than likely it has already been installed if your not having the problem.
Only w/ manuals, there's now a permanent fix: https://www.corvetteforum.com/forums...n-from-gm.html
On GM's dime so take TSB# to a dealer, put this to bed forever.
