Clay Bar Lubrication?
I am not sure that you should use anything other than detailer with a clay bar. You need good lubrication between the clay bar and the paint. I have used a certain clay bar in the past that seemed to stick to the paint (even with plenty of detailer) and left a residue that was almost impossible to remove. I now use Mothers clay bar and get excellent results and their detailer is not too expensive.
Once I bought some Meguiar's claybar that came with lube/detail spray. The claybar caked up after doing the hood. As I had only used half the bar I switched to the other bar and this time used water mixed with a little Zaino Z7 (their wash) it still started caking up. Then tried plain water, worked great. Your results may differ.
If I'm using a fine grade clay on a car with a light level of contaminants, I sometimes use a slightly stronger mix of a car wash solution using a concentrate with ligh lubricity such as Meguiar's Gold Class.
I wash and rinse the car first then mix a fresh batch for claying.
I use a saturated wash mit on my left and and clay behind it with my right hand.
I've heard some say that this dimishes the life of the clay, but I usually work with a small piece and only use it a couple of times before discarding or relegating it for use on wheels.
If your clay bar is caking with contaminants, it's time to knead and fold it.
Zaino suggests using a cap full of their car wash in a 16 oz bottle. Their detail spray is too expensive to waste.
To use Z-18 ClayBar™, you spray a water-based lubricant on a small area of your car and rub the bar back and forth with light to medium pressure. If the lubricant begins to dry, you'll need to spray more. Z-18 is fairly sticky, and cannot be used dry. If you try using it dry, you'll make a big mess. We suggest mixing one cap full of Z-7 Show Car Wash with water in a 16 ounce spray bottle. Z-6 also works as a lubricant for Z-18 ClayBar, but Z-7 Show Car Wash is much more cost effective.
Source: Zaino Z-18 ClayBar
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,426 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Adams waterless car wash provides excellent lubrication for this task.
Ask me how I know.
As someone else metioned, Z6 detail spray is too expensive to use for clay baring, but it will do the job.
Ask me how I know.
I have personally seen at a dealership where they claybar each new Cadillac, they simply have wash the car and while it is wet, use the clay bar on it.
Works for them, works for me.
Being a detailer by trade and a Zaino distributor, we use car wash soap and water. Using detail spray is a total waste of product and money.
Trust me, don't buy into the hype of clay bar lubes, simple car wash soap and water works great and is much less expensive
Alwyn678 (04-09-2016)
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes
2015 C7 of the Year Finalist
Clean a 3' X 3' area, rinse it well and move on.
Elmer
