Installed Block-it!
Installed Block-it!
Don't like adding weight but to kill most of the rear tire noise it's worth
all 20 or so pounds this thing adds. plus it up it makes the Bose sound better. I give it a thumbs up!
TKO Performance (12-31-2015)
The following 2 users liked this post by okbkvette:
joec (12-31-2015),
I bought it from TKO as part of the group purchase. I think it is well worth the investment. It really reduces cabin noise from the Goodyear run flat tires.
Received 2,093 Likes
Race Car Tech
I found that removing the plastic liner in the back wheel wells, and inserting acoustical insulation wrapped in plastic, filling the cavity in front of the rear wheels cut down tire noise by at least 50%.
There is a bit of insulation in a black plastic bag already, but it does not fully fill the cavity.
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
What's nice is if at some time you are looking to hit the track, simply take it out. Like the install, it takes approx 60 seconds to remove. Thank you for your purchase, the kind words and for taking the time to post them!
If you do a search you will see a tremendous amount of positive posts.
Below is a list of some threads from many satisfied customers/forum members.
Within theses threads you will find a ton of others posting their positive results with the Blockit too.
http://forums.corvetteforum.com/c6-c...ation-mat.html
http://forums.corvetteforum.com/c6-c...e-product.html
http://forums.corvetteforum.com/c6-c...ning-mats.html
http://forums.corvetteforum.com/c6-c...d-deadner.html
http://forums.corvetteforum.com/c6-c...irst-ride.html
http://forums.corvetteforum.com/c6-c...rformance.html
http://forums.corvetteforum.com/c6-c...post1573973170
http://forums.corvetteforum.com/c6-c...-block-it.html
Any questions, always feel free to contact us!
Awesome.
Thank you for your purchase!
Great to hear! Thank you for your purchase!
Awesome! Thank you
Thank you!
However if you don't mind removing parts, and you want to take it to the next level, check out our DeadMat!
Thin, light weight. The performance to weight ratio is unreal. Fantastic at removing vibration & noise within your vehicle.
Does not have that "tin foil" look.
Check it out here
http://store.tkoperformance.com/200520131.html
Thank you all. Here's to a happy and a healthy 2016!!
Ed
Group Buy??
I was reading about a past group buy on this product. What are the chances of another group buy taking place again? I am so in if it happens.
Thanks as usual
NSF
