remote got wet, how do I start my car
I went swimming and forgot to remove my remote from my pocket. Now my car will not start. I need to get it started to bring it home. What can I do????
You might have to take your remote apart and just let it dry for a little while and hope it will dry out enough to work agian. If you can't get it to work you wont be able to start your car unless you get a new remote or your 2nd remote for your car. One of them anti-theft features so your car can't be stolen.
St. Jude Donor '08
If you don't have any alcohol; dry it as best as you can and then insert the FOB into the socket inside of the glove box for a better connection and hope for the best when you press the Start Button.
it's unusual that it got water in it. i ran mine through the washing machine and it worked the minute i took it out. many others here have done it too with the same result.
Former Vendor
Fob
Try blowing with air (can or air compressor) and short time under a hair dryer. Should be fine after that. I know I have put mine through the washer and dryer a few times with no problem.
This is news to me? What are you calling a direct connect in the glove box? I must be completely in the dark but I do not believe there is anything to "insert" your fob into in the glove box. Please Explain?
Go look...open the glovebox and on the left side is a slot that is just the right size for the fob. Slide the fob in with the buttons facing to the right side. Then start the car.
Take a look at page 2-9 in both of your owners manuals....
Look for a small rectangular slit inside the glove box on the left side.
I was so excited about the C6 that I read every entry on the C6 FAQ sticky before I even picked up the car and then read the manual cover to cover the first night I picked it up. First time I ever read an owner's manual that I knew more than the manual itself.
Good luck to the OP and hopefully he got the his vette home safe.
I fell out of a kayak once in the middle of the river, and was submerged for about 30 minutes. When I got back, I was soaked, and so was the remote, but the car unlocked and fired right up. Pretty impressed, and relieved since I was 50 miles from home where my 2nd fob is.
Goodluck!
Goodluck!
Goodluck!
Goodluck!
