Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Cleaning and Detailing
- How to Remove Water Spots from Black Paint
Step by step instructions for do-it-yourselfers.
How to remove Water spots from Black paint
I tried Clay Bar and it did good but did not get it all. I remember something about vinegar.
is there a way to remove these spots.
Check out the auto detail section further down in this website. You will get overwhelming responses th ere.
It probably won't for spots that have been th ere awhile. My waterspots happen right after I wash the car and that's when I am able to remove the waterspots with either QD spray and Adam's QD spray smells like strawberries.
Use a car polish, or paint cleaner intended for clear coat finishes.
Note!!! Not wax.
A good paint cleaner that I use is, "Zaino PC Dual Action Paint Cleaner - Swirl Remover."
Another brand that I used before discovering Zaino is, "Meguiars Deep Crystal System Paint Cleaner." This was step 1 of a 3 step system consisting of 1. Paint Cleaner. 2. Polish. 3. Wax. But you can just top the cleaner off with whatever wax you normally use.
Zaino PC has to be ordered, but once you use their products you will never go back to anything else.
Even their leather conditioner is the best I've ever used, and it leaves the smell of new leather inside the car for a couple of weeks.
Detail sprays are for a quick shine on a clean car, they are not intended to remove stains in the paint. Clay bars are for removing foreign particles.
Ed
Note!!! Not wax.
Ed
Note!!! Not wax.
Ed
Note!!! Not wax.
Ed
The Z-9, and Z-10 leather cleaner and protectants smell like leather.
Location: Stafford VA, home of our wolf den. No house break ins to date.
Note!!! Not wax.
Ed
Note!!! Not wax.
Ed
and.. white vinegar, wd 40, or rubbing alcohol will work too.... wont hurt the clear coat..
and again, clay bars dont remove water spots.
Water spots are dissolved minerals in the water (mostly limestone) depending the water supply. Vinegar(acetic acid) will dissolve the limestone safely.
You might want to dilute it at a ratio of 1:1 Vinegar to distilled(or bottled) water and see if thats stong enough.
I have used pure white vineger and it works pretty well, just you and your car will stink.
If vineger doesn't work I would use CLR cleaner and wash my car immediately.
this is my first black car since 2004.
New Black Maxima (Bad A$$ 6Spd lots of fun)
6 months into owning her a post hole digger fell off a truck on the highway and side swiped me. That is when I began to take care of he paint on my cars and it never looked the same
I said no more black cars.
Fast forward to a month ago I said I am ready to handle the upkeep on the black car again. So I bit the bullet.
earlier this week I had some windshield work done and the water tested it.
Then let it sit out in the sun for 3 hours in the 80 degree day.
Now I'm learning about the upkeep on black cars again.
By the way this is for my truck (Still GM Black paint)
But to keep this vette related, My beautiful JSB coupe is sitting in the garage wondering why I'm giving my attention to this big ol truck
By the way, Vinegar took care of the spots. Thanks everyone
Check them out too. I'm sure you will get an overwhelming responses but you got alot on here too.
At my detailing shop, Z-PC and AIO are the only two Zaino products that are applied using a Porter Cable.
