Help: radio won't turn on....
Matt
Engine compartment: #31 Audio Amp
Passenger Footwell: Radio, S-Band, VICS (on my 2008), may differ as per model year.
Again if in doubt, pull the positive battery cable, wait 1 minute, and try again.
M....
Oop - That should be pull the NEGATIVE cable and wait 1 minute.
M....
Did you check the 2 fuses:
Try disconnecting the negative cable - if that fails I would try posting in the Audio Portion of this forum.
Please let us know what happens.
Thanks,
M...
Thanks,
M...
Location: You think your hauling gass then you Then you Look in your Mirror and Oops there I am
Thanks,
M...
Thanks,
M...
Thanks Mike Green9
I have had my C6 for only a few months and went on Vacation for 2 weeks and the battery was dead when i got back. Charged the Batt and when i started the car NO RADIO NO Navi NOTHING. I wigged out thinking I killed it charging the Batt somehow.
Done as you suggested checked fuse and then undone the Neg batt cable for 30 seconds and BAM!!! i got Van-Halen rocking out the speakers again.
Again thanks for the Post I was sweating buying a new head unit.
Success !
It was the radio fuse ( under the toe board, pax side). I pulled it and, at the suggestion of my wife, put it back in without waiting overnight.
Fired right up after I turned the car on.
Perhaps this should be a sticky issue, seems to happen to a lot of folks.
Take it easy, ya'll
Take it easy, ya'll
August McLaurin (09-17-2022)
Removing and replacing fuse worked for me too!!!
This worked for me too!!! Thanks!
Success !
Take it easy, ya'll
Take it easy, ya'll
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Thanx for pulling this old thread forward
Success !
THEN I went to the Corvette Forum to ask about this issue, and as so many have said "Search is Your Friend." Add me to the "lot of folks" to whom this has happened.
Same - 2009 Z06, let the battery get too low (able to barely start the car then not able to start it); charged battery but then head unit would not turn on. Pulled fuse (passenger side behind toe-kick, 3rd from right, 2nd from bottom), inspected it, was fine, put it back in then head unit came on again...
