This widebody stuff is getting ridiculous
Have to say, not practical but it looks bad and I like it.
CF Senior Member
Form trumping function exponentially.
OMG 3 1/2" spacers....
You essentially nailed it. I'm no expert but I think this setup would be detrimental. There are many factors that can come into play but there needs to be an optimal relationship with how the front and rear tires line-up. With this setup the rear tires are pushed out significantly further than the front tires. IMO there's way too much of an 'imbalance.'
Don't you think the Corvette Racing C6.R's would look more like this if it helped?
I think it's ugly too, but you need to research before you type!
Your comment ' no need for that much tire', is ill informed, as that kit utilizes stock Z06 wheels with a 345/25 tire, also using crazy 3 1/2" spacers to kick the wheels out to fill the wells.
SSVette makes the kit.
.......photos snipped........
I am not a big fan of this extra wide body kit , but I do have a question . With the extra spacers needed to push the ZO6 tires out to fill the wheel wells , does the car handle better on a road course due to the widder stance ? Or , would there be a problem because the front tires are still at the stock width ? Any road racers care to educate this Corvette lover ?
Too fat for me.
Moderator
Sometimes more really is too much.
3.5 inch spacers = ridiculous.
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
That's the funny part....that modification generally does NOT result in a wider rear tires...Spacers simply move the tire outward...it's just for show...in fact, with the added load on the wheel bearings Id say it is anything but a performance move
There are some benefits to really wide tires, namely a more sticky rubber composition.
To each his own, but I just can't see how it improves what was an awesome car to begin with.
Reminds me of this silly automotive trend that seems to be everywhere....
#33
Better be upgrading your axles, transaxle, clutch, etc if you really need that much more tire
#34
To coin a phrase commonly attributed to Big Daddy Don Garlits referring to HP:
If some is GOOD, and MORE is BETTER, than TOO MUCH is just RIGHT.
Guess TOO MUCH is TOO MUCH.
#35
Gt
#38
Looks good to me...
Its cool if you simply don't like the look, but I find it very hypocritical that any one who drives a 400-500 HP, 180+ MPH street car would ridicule someone else about what *they* think is "excessive" or "unneeded" on the other person's street car.
Glass houses...
Glass houses...
#39
#40
Looks good to me...
Glass houses...
Glass houses...
