Old 02-20-2015, 01:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Hydraulic Clutch Fluid Replacement
Old 10-17-2010, 07:33 AM
JLB768
JLB768's Avatar
About a year after I bought my Z06, my local Chevy dealership changed my clutch fluid, they did it the way Ranger does, and only charged me for the fluid
Old 10-17-2010, 11:14 AM
John Harry
John Harry's Avatar
St. Jude Donor '10-'11-'12-'13-'14
Originally Posted by Ranger
How the Clutch Hydraulics Work
Ranger:
Thanks for the Service Manual Post. Yes, you are right, there is certainly movement of fluid between the reservoir and the slave - there has to be for the clutch to move.
Old 10-17-2010, 11:19 AM
hawkgfr
hawkgfr's Avatar
Received 1,211 Likes on 823 Posts
Ranger method for the win...
Old 10-17-2010, 11:48 AM
3 Z06ZR1
3 Z06ZR1's Avatar
Originally Posted by John Harry
Ranger:
You can ruin the clutch by NOT FOLLOWING the RANGER Method!
This is must do to your clutch. I bought my ZO6 used with 14k miles.
From Arizona.
The previous owner never looked at the Clutch Reservoir. I did after the car was purchased and brought to me. It had a 1/4 inch of goop
in Reservoir. With the light effort pedal. Too late for the clutch it slipped at 6k. It was changed
for the ZR1 clutch. The old disc looked new with hardly no wear at 14K.
But the pressure plate looked bad. This affects the self adjustment
of the assembly.
Change that fluid using the RANGER method your clutch will love you!
The best tool is not the TURKEY baster. IT is the BATTERY BULB! You know the one for battery water.
Even better than my MYTI Syringe!
It's bigger and sucks every drop out with ONE suck!
Old 10-17-2010, 02:06 PM
gunterwalker
gunterwalker's Avatar
Location: Cape May, NJ; Guntersville, AL; Orange Beach, AL
Great write up!!!!
Quick Reply: Hydraulic Clutch Fluid Replacement
