Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-20-2010, 09:57 AM   #1
01redvette
Junior Member
01redvette's Avatar
Default Optima Battery for C6
Need some advice. Wanted to replace my battery (before it gave my computer a acid bath) with a Optima Red Top. My battery friend told me Optima doesn't make a recessed post top model that the C6 required. If this is true what has very body been using. I have the battery cover and want to make sure it still fits. Do I have a choice or do I need to stay with the old battery technology ?
01redvette is offline   Reply With Quote
Old 03-20-2010, 10:34 AM   #2
C6 MoneyPit
CF Senior Member
St. Jude Donor '06-'07-'10
C6 MoneyPit's Avatar
Here you go -
http://forums.corvetteforum.com/c6-p...5-shipped.html
C6 MoneyPit is offline   Reply With Quote
Old 03-20-2010, 12:21 PM   #3
lefthander
CF Senior Member
St. Jude Donor '07-'09
Send a message via Yahoo to lefthander
Just replaced battery in my 07, C6 last week. Went with the Optima red top. I also have the battery cover and it works just fine.
lefthander is offline   Reply With Quote
Old 03-20-2010, 12:31 PM   #4
j_digi454
CF Senior Member
Support Corvetteforum!
j_digi454's Avatar
Quote:
Just for info, could you post which model you used. Thanks.
I assume it fit with the OEM hold-down bracket.
__________________
JD
2007 C6 Coupe A6
Monterey Red, Two-Tone Ebony/Titanium, Polished Wheels
3LT, F55, NPP, PAL, E-Force, 160* Thermostat, MSD Wires, ARHeaders & Hi-Flow Cats
1970 Corvette Bronze C3 Coupe 454/LS5 - Sold
j_digi454 is offline   Reply With Quote
Old 03-20-2010, 01:05 PM   #5
PO10TIAL
CF Senior Member
PO10TIAL's Avatar
I think I used Optima Red Top 34/78..... I think you have to put it in backwards so the terminals reached. You get a new bracket with the battery and it fits the C6.....
PO10TIAL is offline   Reply With Quote
Old 03-20-2010, 02:48 PM   #6
j_digi454
CF Senior Member
j_digi454's Avatar
Quote:
Thanks for the info, I'm close to needing a new battery and have been thinking of the Optima Red as a replacement but was concerned about using the existing bracket.
Old 03-20-2010, 03:58 PM   #7
orca1946
CF Senior Member
orca1946's Avatar
Feb 2006 & still running fine - also my daily driver , maybe why it lasts longer than a stored one .
orca1946 is offline   Reply With Quote
Old 03-20-2010, 04:03 PM   #8
SilverScorp
CF Senior Member
SilverScorp's Avatar
I have a optima red top in my car and used the old bracket, works fine.
SilverScorp is offline   Reply With Quote
Old 03-20-2010, 04:14 PM   #9
Keith N
CF Senior Member
Keith N's Avatar
Quote:
Same here, my 2006 is the oem battery. My C6 isn't a DD, but it's driven every weekend. I'll probably be looking at an Optima battery soon. What is the difference or recommended for a C6 Coupe - yellow or red?
Keith N is offline   Reply With Quote
Old 03-20-2010, 04:20 PM   #10
SilverScorp
CF Senior Member
The red top has more cold cranking power whereas the yellow has more (operating?) power. They way I was told is that you don't need a yellow top unless your running a high amp sound system with a lot of wattage, or some other high wattage electronics.
Old 03-20-2010, 04:35 PM   #11
C6 MoneyPit
CF Senior Member
The yellow top can withstand discharge-recharge cycles without hurting the battery. It's recommended if you have a high-amp sound system or a lot of other electrical devices, like DVD players, etc.
I would go with the yellow top. The cold cranking amps are only a little lower than the red top. I had a red top and it died in 1 1/2 years, I think because I let it go dead. After that, it would not hold a full charge. I'm waiting to see if Optima is going to replace it. It obviously has an internal short.
With the yellow top, even if it does go dead, you can recharge it and it is as good as new.
Or you can go to Costco and get a 100 month battery with 36 month free replacement for $60, less than 1/2 the cost of the Optimas.
Old 03-20-2010, 05:14 PM   #12
lefthander
CF Senior Member
Used the 75/35 red top. Did not change brackets, sat it in place and hooked it up. Added velcro at top edge on side and replaced battery cover. End of install.
Old 03-20-2010, 05:18 PM   #13
inthehunt2
CF Senior Member
inthehunt2's Avatar
http://www.facebook.com/?ref=home#!/profile.php?id=1118875825 http://www.linkedin.com/profile/view?id=16824787&trk=tab_pro
Send a message via Yahoo to inthehunt2
Here's what pulled down from the Optima website...
PRODUCT: Battery
VEHICLE: 2008 CHEVROLET CORVETTE 6.2L : 376-cid : V8 : GAS
OPTIONS: None Selected
PREFERENCES: None Selected
Part List
Not sure which option is right for your vehicle? Read about the product lines below to determine the best match, then click on part number to view images and product details.
RedTop: High-CCA starting battery. Provides engine cranking power for vehicles with stock or average electrical loads.
YellowTop: Dual-purpose starting and deep cycle battery. Provides engine starting power plus deep cycle capacity to support multiple accessories , demanding electrical systems , and vehicles without alternators.
2 Parts Found
Group # Description
35 (8020-164) RedTop®; Battery;
D35 (8040-218) YellowTop®; Deep Cycle Battery;
inthehunt2 is offline   Reply With Quote
Old 03-20-2010, 06:03 PM   #14
78PC
CF Senior Member
78PC's Avatar
Default Perfect Fit
Hello Terry
A YellowTop D35 will fit a 2005 Corvette.
Thank you,
Daryl
Optima Customer Service
78PC is offline   Reply With Quote
Old 03-20-2010, 06:23 PM   #15
FZovko
CF Member
FZovko's Avatar
Send a message via AIM to FZovko Send a message via MSN to FZovko Send a message via Yahoo to FZovko
Default Go with a Diehard
I spent nearly $200 on an Optima Yellow Top. It didnt even last the year. I am back with my stock AC Delco. Advanced Auto wouldnt do a replace on the battery. Save your money and buy a Diehard and a Trickle Charger.
Nothing more annoying than a $60K car that never starts. Good Luck.
P.S. I bought into all the Optima love on the site and decided to avoid battery failure due to DBS. Dont waste you $$$ IMHO. At least Sears stands behind their products. I figured I did not have a battery problem dealer tested the Optima and it was bad!!! I let the dealer junk the battery. Im so pissed. No more Optima's or Advance Auto for me.
FZovko is offline   Reply With Quote
Old 04-09-2010, 07:10 PM   #16
Watchwait
Junior Member
Watchwait's Avatar
Can someone point me to a photo of the "battery top" that is being referred to here? Was this a stock Corvette item? I cheked GM Parts House, and I see something called a Battery Hold Down and Battery Bolt. Is this some special type of battery dentention system?
Watchwait is offline   Reply With Quote
Reload this Page Optima Battery for C6
Tags
06, 2005, 2007, 2008, batery, battery, c5, c6, clamp, corvette, hold, optima, red, top, yellow
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
