Why do my dashboard lights go dim when headlights turned on?
Old 03-19-2010, 07:17 PM
vettemann62
vettemann62's Avatar
Default Why do my dashboard lights go dim when headlights turned on?
C6 2007
Why do my dashboard lights go dim when i turn my headlights on? When they are off the dash is bright. Is there a dimmer I don't know about?
Old 03-19-2010, 07:21 PM
2kvert
2kvert's Avatar
It's supposed to do that. They dim so you don't have bright lights glaring in your face. You can brighten them back up with the dimmer switch to the left of the steering column.
Old 03-19-2010, 07:27 PM
cclive
cclive's Avatar
Yup....if the dash lights were the same brightness when driving at night, they would bother your night vision.
Old 03-19-2010, 07:45 PM
vettemann62
Thanks so much guys. I wasn't holding the dimmer switch long enough for the dash lights to brighten.
Old 03-19-2010, 10:43 PM
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
Like in a submarine or other 'night lighting' environment....the lighting dims to protect your night vision.
Old 03-19-2010, 10:58 PM
inthehunt2
inthehunt2's Avatar
BINGO!
Most OEMs today have different levels of backlighting for daytime and night time illumination levels. F.Y.I.
Old 03-19-2010, 11:36 PM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
One of the things that's very cool about our Corvettes, though, is that the dash lights (and nav screen for those so equipped) don't just get dim when the headlights are on and bright when the headlights are off. The brightness of the dash lights is also determined by a separate ambient light sensor. If it's bright outside and the headlights are on, the dash lights will still be bright. Likewise, if it's not very bright outside, the dash lights will be dim even if it's not so dark that you need the headlights to be on. Pretty cool IMO.
Old 03-19-2010, 11:44 PM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Originally Posted by mpuzach
Pretty cool IMO.
Indeed.
To Why do my dashboard lights go dim when headlights turned on?
Quick Reply: Why do my dashboard lights go dim when headlights turned on?
