My XM bands just disappeared! Any ideas?
Old 03-19-2010, 09:58 AM
JBOSS
JBOSS's Avatar
Default My XM bands just disappeared! Any ideas?
The XM1 and XM2 bands just disappeared off of my head-unit (2007 model year). I only get FM1, FM2 and AM when I cycle through with the band button. I installed a USA Spec PA11-Vette iPod adapter over 2 years ago and it has worked great until this past Monday. At the same time that I noticed the XM bands were missing, I also noticed that my FM presets were gone. Possible battery issue? Why would the bands just disappear? It just figures that my car is exactly 3 years old and just went out of warranty!
Any ideas? Of course, I will check for loose connections, but I thought that I would check real quick with you guys to see if there is something that is "known" that I should be aware of.
Thanks!!
Old 03-19-2010, 10:03 AM
not08crmanymore
not08crmanymore's Avatar
Just keep hitting the band button or turn the radio off for a minute.Did that to me last week,and it wasn't the 1st time.
Old 03-19-2010, 10:53 AM
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The most common cause of the XM bands completely disappearing is due to the connector coming loose at the XM module. If your car is a coupe the XM module is located over the driver's side wheel well behind the carpet. If it is a convertible it is located inside the waterfall cover behind the center console. Should be an easy fix.
Old 03-19-2010, 10:54 AM
JBOSS
JBOSS's Avatar
Excellent. I'll give it a try. Thanks for the tips guys!
Old 03-19-2010, 11:00 AM
NVR LAT
NVR LAT's Avatar
Talon 90 beat me to the punch...as usual, but he's right, I've gone through this problem trying to install a PAL unit. Find the bad/loose connection and they should come right back.
Old 03-19-2010, 08:23 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
I've had the same thing happen to my Hummer as well. I just unplug the battery for about 30 minutes and when I reconnect the batter my bands are usually back. Try that if nothing else works.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 03-22-2010, 09:38 AM
JBOSS
JBOSS's Avatar
UPDATE: I checked all of the connections and everything looked fine. I decided to pull the PA11 unit and plug everything back to factory. My XM bands returned. So, I reinstalled the PA11 and everything works just fine now. Go figure. Must be a bad connection. Hopefully, it will not be a consistent problem.
Thanks for the tips guys.
To My XM bands just disappeared! Any ideas?
Quick Reply: My XM bands just disappeared! Any ideas?
