Rear Side Marker Lights
Had the pleasure of driving my Z06 from Houston to visit San Antonio this past weekend and had a great time. The Z drawing onlookers throughout the trip, with one unfortunate circumstance... one of San Antonio's finest decided to inform me that the rear side markers on my car are required by law to be red. This in turn led him to feel obligated to write me $167.10 ticket for my obvious infraction.
I'll take care of the ticket but following the incident I started looking and I've seen both red and yellow rear marker lights.
Anyone have any insight as to the difference in the color of these lights... red vs yellow?
Just out of curiosity are your clear or blacked out? If they are clear, do they have red lights in them?
The reason I am asking is we had a discussion about this very topic in another thread not long ago.
OH yes, I haven't seen yellow or orange on the back corners. Amber lights are usually on the front corners. Some run clear front corners with amber bulbs.
I've recently seen a few yellow lights on the rear of a few vettes in different magazines but I honestly never thought much of it until now...
Try this, then check your state requirements
0018] The Department of Transportation (DOT), in its Federal Motor Vehicle Safety Standards, 49 C.F.R. .sctn.571.108 (2000), or "FMVSS 108," regulates all lamps, reflective devices, and associated equipment. FMVSS 108 can be found at www.nhtsa.dot.gov and is hereby incorporated by reference in its entirety. DOT Standard 1383 (part of FMVSS108) adopts the Society of Automotive Engineers (SAE) Standard J592 (July 1972 and August 2000), J2042 (September 1996, March 2000, and March 2003, and J578 (February 1977) for motor vehicle clearance, side marker, and identification lamps.
[0019] SAE Standard J592, paragraph 3.1 defines a "clearance lamp" as a lamp "mounted on the permanent structure of the vehicle as near as practicable to the upper left and right extreme edges that provide light to the front or rear to indicate the overall width and height of the vehicle." SAE Standard J592, paragraph 3.2 further defines a "side marker lamp" as a lamp that is "mounted on the permanent structure of the vehicle as near as practicable to the front and rear edges, that provide light to the side to indicate the overall length of the vehicle." SAE Standard J592, paragraph 3.3 defines "combination clearance and side marker lamps" as "single lamps which simultaneously fulfill performance requirements of clearance and side marker lamps." SAE Standard J592, paragraph 3.4 defines an "identification lamp" as "lamps used in groups of three, in a horizontal row, that provide light to the front or rear or both, having lamp centers that are spaced not less than 150 mm nor more than 310 mm apart, mounted on the permanent structure as near as practicable to the vertical centerline and the top of the vehicle to identify vehicles 2032 mm or more in overall width." Unless otherwise noted, the SAE definitions of these terms are adopted and used herein. The lamp of the instant application is intended to be used in any or all of these applications. The various embodiments discussed infra will satisfy all SAE standards for photometric requirements as well as chromaticity.
[0020] SAE Standard J592 also specifies certain minimum and/or maximum luminous intensity requirements for vehicular lamps functioning as clearance, side marker, and identification lamps. According to the aforementioned standards, a minimum luminous intensity must exist at various points in the illumination zone to be in compliance. These specific photometric requirements for clearance, side marker, and identification lamps, as set forth in SAE Standard J592, are included herein below.
So you have a 2008 Z06 that you bought new (and hasn't been modified by a previous owner) that has amber lights on the back rear corners?
That seems unusual to say the least. All Corvettes that I have seen have amber fronts and red rear side markers.
I've looked at pictures of european C6s and every one has red rear side markers...even the new ZR1. If GM made the car with the wrong color, then they should be responsible for it...the car is supposed to meet all vehicle code standards in the 50 states. If they will admit the mistake, then you can take that admission to the judge and get the ticket dismissed.
European Vettes have all amber side indicators, front and rear.
If you bought the car new and are sure nobody changed them, maybe it was an oh-oh in the factory, they build them mixed (US and Euro versions), so maybe somebody messed it up...
Sonny
Thanks for all the responses... I have not modified the rear markers they are yellow or amber. When the patrol car showed up behind me I ran through everything I had done to warrant being pulled over and I honestly didn't do anything that would have prompted the attention I got. I don't want to bash the officer maybe an uneventful night or a bad day who knows. In any event I will take the car back to the dealership and ask them to change the markers out and show them the ticket I recieved.
During the stop I handed him my concealed handgun license with my driver's license he actual threw it back at me and said I didn't ask for that. Then proceeded to question me on whether or not I had my weapon on me... When he was done printing out my ticket he dropped it in the front seat and walked off... I sat there wondering if there was more to follow... fortunately there was not. For what it's worth I will file a complaint with the San Antonio police department I don't feel his antics were warranted. You know you try to keep respect but sometimes people’s actions make it difficult....
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,460 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I would get a statement from the dealer that this was a factory flaw and take the citation to court. I'm sure any judge worth his weight would throw this out. It sounds like you caught an LEO having a really bad day. That's no excuse for the rudeness, though.
On my plant tour, a export vette was pointed out to me, with the comment " the export models have amber side markers"
Export cars change in the following ways (FYI)
Rear Side Marker is Yellow
Outer Rear Tail Lamp is Amber on bottom (for Turn Signal) and Red on top (for Brake and Running Lights)
Inner Rear Tail Lamp is Red (for Rear Fog Lamp)
Fender Amber Signal Lamp is added
Provision for European Plate Mounting Front Bracket added
The dealer advised that I should call the parts department with my VIN and they will look up the issue with the marker lights.
If it was a 2010 I would just think blame it on a government conspiracy to increase revenue.
Sounds like you should be able to fight this in court, but the time and effort will probably equal the cost of the ticket in the long run. Three or fours hours out of your day, sitting in court might equal $160. Maybe GM could reimburse you for the ticket.
