On battery disconnect, what needs to be reprogrammed?
As noted, the only thing you will lose are the window index settings. All of the other items you mentioned will remain in tact.
Received 8,954 Likes
Only indexed!
I have an 06 C6 A6 F55 NAV and I lost nothing, just reindexed the windows. I have disconnected the battery several times and the dealer has also replaced the battery, same story.
Location: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
1 Post
I was surprised last yr. when I reconnected the battery.
All I had to do was re-index windows. Radio presets, oil life monitor, personal greeting were all there.........
Received 2,062 Likes
Average mph, mpg, elapsed time, and trip mileage all reset to zero. If any of that is important to you, then write it down before the disconnect. You can't put that info back in the system.
Interesting. I have had my battery disconnected several times and I've never lost anything in my navigation radio. There is no "backup battery" so no you don't need to replace it.
