Urgent- auto gear locked out of R and P
Automatic 2007 coupe 3lt z51. Just bought the car a few days ago, has 11k mi. on it. Just got it home, can not shift into reverse or park! off or on, brakes, no brakes, just goes between Drive and Neutral. Had foot on and off the brake while trying to do this. Dash reads shift to park, but can't. Anyone know anything about this?
When you press the brake can you hear any noise inside the cabin at all? Pressing the brake should release the lock allowing the car to go into park, d, etc... I'm not a mechanic though, there are other people on here more knowledgeable i/m sure.
Probably a Park-Lock soleniod malfuction. The soleniod is located on the shift lever, and activates when you press on the brake to unlock the gear shift lever to allow a shift to reverse or park position. Press on the brake pedal with the ignition on and see if you can hear a small clicking sound each time you depress the brake pedal, if you do not, the soleniod needs to be replaced. You have to remove the console and gear shift lever assimbly to get to it. Good Luck. I had the same problem on a road trip, and took a piece of wire to hold back the spring lock release, until I could get repaired with a replacement shift assembly.
No noise heard when pressing the brake. Thanks.
Location: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
You're gonna need to replace the entire shifter assembly as I just had the exact same thing happen last week to a friend's car and it's a common problem unfortunately. If it helps any, you should be able to at least get it into Reverse by squeezing the shifter button as hard as you can while trying to move it from Neutral.
Taillights work OK?
From post #6 at http://forums.corvetteforum.com/c6-c...-in-drive.html
"Check your brake light fuse. If the tranny isn't sensing that the brake is on it wont shift passed N. I've seen the same thing happen but in park. No brake signal shifter wont move."
A weak/dying battery might prevent something electrical from working properly, like the brake switch or the solenoid in the shifter console, which prevented you from shifting.
A new battery seemed to fix it here (post #28 & 29) http://forums.corvetteforum.com/c6-c...urn-off-2.html
But I DO NOT suggest you force the shifter! Might do more harm than good.
This is definitely fixable. Let us know what happens.
