***WARNING Super Low C6 pics HERE***
So I decided to have the car lowered last week. I didn't want to cut any corners (or bushings) so I decided to go with the super high quality Delrin Hardbar bolts for the rear assuming the stock front bolts would do the job as I hadn't heard of anyone on here needing aftermarket bolts for the front. Well, if you wanna get low, and I mean low - you need the bolts so I had the Delrins also installed in the front and turned almost all the way down.
The center of the front wheel well fender is 25 1/2'' from the ground and the rear is 26 3/4'' approximately. I now have less than 2 inch clearance for front plastic guard and it scrapes on everything now.
The car rides great, no strange noises, no rubbing on sharp turns and I love the aggressive stance. I had Dan at Vetteworks in Auburn WA do the install and I was very impressed with the quality work he did. I reccomend him and Delrin Hardbar to anyone.
Dan Hagerty of Vetteworks
http://vetteworksonline.com/
The car rides great, no strang noises, no rubbing on sharp turns and i love the aggressive stance. I had Dan at Vetteworks in Auburn WA do the install and I was very impressed with the quality work he did. I reccomend him and Delrin Hardbar to anyone.
http://img19.imageshack.us/i/023mrf.jpg/
http://img688.imageshack.us/i/021sn.jpg/
http://img18.imageshack.us/i/019wi.jpg/
http://img694.imageshack.us/i/018hjw.jpg/
http://img514.imageshack.us/i/017lmy.jpg/
http://img85.imageshack.us/i/016so.jpg/
http://img651.imageshack.us/i/013ri.jpg/
http://img683.imageshack.us/i/012syh.jpg/
did you align it at all?
I embedded all the pics now so you guys don't have to clink on links.
Gonna wait a few weeks for everything to settle and then fine tune for even height side to side and front to rear before alignment
Great full service shop. GMPP Warranty work as well.
Car looks
In a few weeks when you are ready for the alignment, I bet you will also be ready to raise it back up. That is just too low and is going to start costing you money. Better buy spare air deflectors and lower radiator support now.
Z//
The car is actually lower now (in the front) than when this pic was taken
Is the only reason to do this for the track? I could not see putting that on the road unless you wanted to be the one scraping up all of the dead squirrels, but then where would you put them when they clogged up your air filter?
It looks good--sitting still.
He does excellent work. I 'm having him put my headers on in a couple months
Looks awesome. Mine is lowered but not quite that far. I have had a 2 of my plastic spoilers destroyed. Most recent was Friday night, I hit a small block of ice on the highway. I'm thinking about taking it off for good.
