Heads Up Display Kits In Stock - www.PartsTaxi.com
Former Vendor
These have become a very popular upgrade for the C6. A good DIY afternoon project. This is plug and play, our kit plus the harness that can be obtained on the forum and you're in business. I currently have 12 kits in stock and more on the way.
HUD Display - 15934351 - $225.98 NEW LOWER PRICE!!!!!
HUD Switch - 20844868 - $30.72
HUD Bezel - 19121990 - $20.04
You will need a custom harness for this application. There is a forum member here who sells them for around $75 I believe.
Thank You!!
Kevin
www.PartsTaxi.com
Thank You!!
Kevin
www.PartsTaxi.com
Former Vendor
There are 2 members that sell these harnesses. Either op z (Patrick) or intercooled C6 (Larry). They are both great guys to deal with.
Kevin
www.PartsTaxi.com
Kevin
www.PartsTaxi.com
Former Vendor
Here you go. I have PCMUSICGUY's DIY on my website. Here's a link to a pdf.
http://www.theredlion.us/C6%20HUD%20...%20Rev%202.pdf
Former Vendor
The way we did it was loosen up the dash with out removing dash or cutting anything and took a good 8 hours.
The first time I used a fine toothed saw blade, the last couple of times I used my Dremel. Once the duct is removed, you simply place the HUD over the studs. I used plastic loctite and gorilla tape to re-secure the duct.
Fits like a glove...
