Clay Bar a glass top?
Although I have not done it, according to everything I have read - YES, you can clay bar "GLASS". Keep in mind, the Corvette tops (targa) are not glass, they are "Lexan" (plastic). I do not know if you can clay bar Lexan.
Received 2,045 Likes
St. Jude Donor '13
The top has a very thin layer of protective (anti-scratch?) stuff on it, I'd be hesitant to clay it until I heard from several folks who had no problems later on.
1 Post
St. Jude Donor '09-'10-'11
Clear Top Cleaner
NOOOOOOOOO! DON'T DO IT. I use a special spray specifically designed for this purpose called PLEXUS. Go to www.PlexusPlasticCleaner.com It's the ONLY thing to use on them.
Us a good Plastic Cleaner/Polish, 3M, or Plexus is what I use at my detail shop. Look for some inexpensive 100%cotton applicators at Kragens.Chuck's/whoever. They come in a package of 4 for about $4.
Plan on using all 4. Divide the top into 4 sections and use the cleaner and a new applicator. When you have finished with the first 1/4, go to a new applicator, unless it is still very clean. If your top is dirty, the applicator will load up with dirt. If you continue to use it, it will scratch, that is why you rotate applicators.
Just use Plexus regularly and your top will look and feel great.
(Don't forget to use it on the inside, too.)
Location: Stafford VA, home of our wolf den. No house break ins to date.
clay bars remove airborne contaminants from the clear coat surface as they become embedded. You accomplish nothing by claying the clear roof.
I will be using Zaino Plastic polish on mine when and if its needed. right now, it has two layers of zaino z5pro with zfx on the inside and outside and looks fab.
Well I will jump on here and disagree. My car is a DD and sees lots of road grime. I had plenty of over-spray and road contaminants on my clear top and clay bar was the only thing that took them off. It didn't leave a single scratch on the top either.
You can pick it up at Tap Plastics, and it comes in various forms of abrasive. From strong to very mild. I also use it on my headlight restores to remove the sanding scratches.
I found the Zaino plastic polish to be very, very mild, and simply did not do the trick on even the lightest grime and scratches, where as Plexus definitely did the trick. It is great for bringing up a shine after cleaning. And this is coming from a Zaino distributor
I use Honda cleaner/polish. It's pretty much the same stuff as Plexus. Actually I have used it all over the cars body work. You can pick up either product at a motorcycle parts dept.
