Odyssey Battery Installed in my 2007
After much research and discussion I decided to install an Odyssey in my 2007. Here are some notes and pics:
1. The only correct battery is the PC1200MJT. It is a metal jacket and the SAE terminals are in the right orientation. The larger Odysseys will not fit.
2. I bought mine from West Coast Battery along with a hold down bracket HDS that they say they had fabricated for GM cars. The bracket is shown in a pic below.
3. Look at the pic below of the battery tray and you will see a lip on the back. The protrusion on the HDS fits under that lip and the hole on the other end of the bracket is for the GM bolt from the stock wedge on the front side of the battery. The GM wedge is not used.
4. Of course the bracket is installed after the battery is placed in the tray and the bracket is very secure.
5. The battery arrived fully charged and I cannot tell any difference in engine starting. I doubt that I will ever be able to tell any difference from a standard wet cell, but I will rest easier knowing that I have an Odyssey in there.
Larry
Larry
The Odyssey Red Top fit in my 2007 A6 just fine without the need for additional hold-down brackets. When I contacted Odyssey about the proper fit for an 07 C6, they did not claim to have a battery that fits our vehicles... but the Red Top fit works great with OEM bracket.
You'll love the dependability of the Odyssey!
This is an Odyssey, not an Optima. Different brand, different technology, different size. My searches did not result in anyone having installed an Odyssey in a 2006+. Although, I believe the Sears Platinum is made by Odyssey, with the terminals reversed. Oh, the Odyssey has straight sides so the GM method of securing will not work.
Larry
Larry
cthusker swears by the Odyssey and that's good enough for me. That would be the battery I'll change to.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Does this fit the 2008 coupe? I may be wrong but didn't the battery change for 2008 and beyond? I have always heard good things about Odyssey so it would be a great option for me when the time comes if it fits.
Former Vendor
I have used many Odyssey batteries from the smallest to close to the largest in street cars, race cars audio comp systems, simply the best I have ever used and the only ones I buy. When the stock batteries die in my dually I am putting to really big ones in though a couple of 1200's would probably do the trick, that good!
I like to buy them with the metal jacket, take it off and make a battery box from it, cut into the floor in the rear of my audio comp time attack car is one way I used it.
I have had one fail out of many and it was my fault, left it out over the winter with no charge in it, two others in the coldest corner of my only part time heated shop did just fine though it they died would of been my fault as well. Take care of these batteries and they last for many many years.
Optima, I have known of many failures, some very premature, but the yellow top in my old audio comp truck lasted 10+ and 3 of that I hardly ever started the engine or charged the battery, total neglect and it last through 2 cold winters of it before it died. That was one rare Optima!
Rick
Rick
Larry
Larry
How about a pic of the installed battery?
I have an Odussey in one of my Harley's. It's going on 9 or 10 years ---maybe longer (I had it in another bike before this one). You will notice they last longer. They won't just die overnight on you. They eventually grow weaker which is very nice. You will know when it's time to start looking for a new battery instead of finding yourself stranded.
Miami08, I cannot give you a pic of it installed because my intercooler reservoir sits on top of the battery and you cannot see the battery.
As for the 08+ question, the 08 battery shows as a group 85, where the 07 is a Group 90. I don't know the dimensions of the Group 85 battery, so you will have to do some research. The Odyssey 1200, that I installed, is about 1.5 inches shorter than the stock battery. The Odyssey Factory site does show the same battery, the PC1200MJT, as the correct battery for a 2008 also.
Larry
Larry
I bought this same battery as a replacement for the oem on my '08Z. Is there anything I need to do other than just pull out and drop in the new one? Its the electrical system I am concerned with once I remove the battery.
Re-index the windows
ABBASOLUTELY!! If you have a vert with power top, the top won't operate unlesss you re-index the windows after the battery is disconnected - or run all the way down. It took me 2 hours of cursing *#@*# power top until my better half read the whole section on top operation and, discovered that little tid bit a couple of pages in.
Les
Les
