Another Lowering Question
Has anybody had their car lowered at the dealership? I was wondering if they'd do it. If so, seems rather logical since you could have it aligned at the same time. Thanks
Moderator
Received 3,589 Likes
Lotsa dealers will do most anything for money! A good alignment shop would probably do it too - find one that aligns race cars and ask.
JD
JD
What will happen at the dealer is first they will tell you not to do it. In some cases they may also tell you it will void your warranty. If you insist they will charge you $65 per hour shop labor then insist you do a four wheel alignment in their shop for $150.
If you do it yourself, turning the four 10MM adjusting bolts is free. Take it to a good alignment shop for a four wheel alignment for usually less than the dealer. You just saved more than the $65 shop labor cost and can uses those $$ for other good mods.
Received 8,958 Likes
Dealership Service Managers typically do not like to do mods. Their business is bringing cars in, doing defined service/repairs on those cars and getting them out the door ASAP so they can get the next one in. If they agree to do a mod for you they usually charge more to do it.
Bill
Bill
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
I had mine done at a dealership in Orlando who happened to have a Corvette performance shop. They did my widebody, cut my bushings, lowered and aligned.
Did an awesome job, on all of it, painting the rear quarters too.
David
David
