Drone and Foam
CF Senior Member
Personally, if I had drone I'd eliminate the problem at the source instead of trying to cover it up. My gut reaction to your foam idea is don't do it but honestly, I don't know anything about it (most of the guys I know remove carpeting, etc. to lighten their car). I know Dynamat insulation is widely used in the cargo area and around the wheel tubs though. Good luck!
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
I don't know if it'd work; might be worth a shot. Only issue I might see is, heat. I don't know if the foams that I've seen used in construction are rated for heat, and at least in the back, there's a lot of heat from the exhaust. Make sure it doesn't become an issue first because we'd rather not read about a recent WB conversion that burned up.
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
You might want to consider checking out BLOCKIT
Super simple. Real effective. Takes the edge of interior noise from exhaust & tire noise.
Hopefully the search function will work for you (its on the blink right now) but there is a ton of threads and posts about it
We just sold out but we are doing another run and should have them in about 2-3 weeks.
CLICK HERE http://store.tkoperformance.com/acousticsystem.html
Ed
Ed
__________________
Serving The Corvette Forum For 23 Years!!
Allow us to add you to the list of extremely satisfied customers.
Order Securely Online 24/7: http://tkoperformance.com/index.html
Feel Free To Contact Us By Phone: 1800 -778- 9898 Monday- Friday 9:00am to 4:30pm
Click Here: http://www.facebook.com/pages/TKO-Pe...e/367433626633
Please don't foam!
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
Foam would be a mistake. That stuff expands with quite a bit of of force. You could easily pop out a body panel. DON't do it !
The problem with exhaust resonance ("drone") is that it is a low frequency noise. Insulation or foam will not supress it. Low frequency sound energy will penetrate anything. To fix it - you have to remove the source.
I have followed "drone" threads here for 9 years. I even went through it myself w/ my C5 and a certain aftermarket exhaust. It's sad to see how many people keep throwing good money after bad with x-pipes, dynomat, etc,
If you have an aftermarket exhaust system that is anything other than Corsa, it will probably have resonance issues that will never be eliminated.
