Constant Buzzing behind Dash (Cluster)
Old 11-23-2009, 10:27 PM
knkali
knkali's Avatar
my wife calls this place the "oracle".
Old 11-24-2009, 07:36 AM
beav626
beav626's Avatar
well I got in the car this morning and no buzzing.... so far so good
Old 11-24-2009, 06:58 PM
kd6awa
Cruising
kd6awa's Avatar
I had the same problem with the temperature sensor fan last winter when the cold weather finally arrived (and the car was only a few months old). I think the sensor being mounted to the dashboard amplified the buzzing sound so I simply disconnected it from the dashboard and left the sensor hanging by its wires. Problem fixed (to my satisfaction, at least).
Old 11-24-2009, 08:06 PM
beav626
beav626's Avatar
Have you had any issues with inside temperatures? Like not reading the temps accurately?
Old 11-25-2009, 06:35 PM
kd6awa
Cruising
kd6awa's Avatar
I haven't noticed any issues. I figure the sensor's now sampling the air that's directly underneath the dash (since the unit is now simply hanging from the wire) rather than from in front of the dash. And my usual setting is floor vents only but it doesn't seem like the sensor is seeing just the heated air from the vents. I leave the inside temperature set at 74 and even with an outside temp of the high 40s or low 50s, it's comfortable.
Old 11-26-2009, 05:36 PM
beav626
beav626's Avatar
Old 12-02-2009, 09:40 AM
beav626
beav626's Avatar
Every once in a while that wire keeps rubbing the fan and it begins to buzz again...
Old 12-02-2009, 10:00 AM
Nate's first vette
Nate's first vette's Avatar
I have that buzz too. it's at chevy right now. I'll post later if they fix it.
Old 12-03-2009, 03:48 AM
Mel 2001
Mel 2001's Avatar
This is unbelievable!
I was going crazy wondering where that buzzing sound was coming from. It sounded Like it was coming from the engine compartment. But what could be making that sound from there?
Thanks for the OP. I hope the dealership has good ears.
I plan on telling them about the Buzz, the cracked starter button and the noisy differential, when I bring it in for my oil change.
Old 12-03-2009, 09:25 AM
beav626
beav626's Avatar
last night mine was intermittent and annoying... My girl was asking why is the radio up so loud...
Old 12-06-2009, 06:47 PM
beav626
beav626's Avatar
did they fix it?
Old 12-06-2009, 08:31 PM
User 2623
User 2623's Avatar
Another considerations regarding Buzzing or Vibration noise which seems to be coming from inside the dash. This is however dependent upon speed, wind velocity and sometimes direction.
Check your windshield cowel - the black plastic strip below your windshield wipers and covering the lowest part of your windshield.
Basically tape it down alternating each side take it on the highway see if the buzzing or vibration stops. If so get it replaced at the dealer- warranty service for those who still got it.
Nonetheless it's responsibile for a number of complaints about dash vibration or buzzing. Check it out might work for you.
Old 12-06-2009, 09:32 PM
  #33
jordyt123
jordyt123's Avatar
Had the same noise and the cowl vibrating at speed was the culprit.
First time the dealer used silicone to adhere the cowl piece to the window. Noise stopped but the cowl piece started to tear at the seams. Dealer replaced the whole cowl piece.
Old 12-07-2009, 12:39 AM
  #34
Buffalo3
Buffalo3's Avatar
Raider, thanks for the info. I've got the same buzzing and have been searching in vain for its location.
Old 12-07-2009, 12:45 AM
  #35
gbgary
gbgary's Avatar
i have this issue. taped it down to confirm my guess and all was quiet. took the tape off...noise. i hate to take it to the dealership but i guess i'll have to.
Old 12-07-2009, 01:45 AM
  #36
Rossi6998
Rossi6998's Avatar
I love this forum and now know what the buzzing problem is. Now, I have to determine if the buzzing is more annoying then some mechanic ripping my dash apart and possibly creating another problem....
Old 12-07-2009, 09:25 AM
  #37
beav626
beav626's Avatar
mine gets more annoying everytime I drive the car...
To Constant Buzzing behind Dash (Cluster)
Old 01-19-2010, 02:14 AM
  #38
GotGrunt
GotGrunt's Avatar
I have the same buzzing sound... you can only hear it with the engine and accessories off while the ignition is in the run mode.
Old 01-19-2010, 07:40 AM
  #39
beav626
beav626's Avatar
I have pulled that little fan out (The one next to the ignition button) and found that to be the culprit. I will take it to the dealer for replacement as the part is like $60-$70
Old 01-19-2010, 08:06 AM
  #40
GotGrunt
GotGrunt's Avatar
Yeah, that's definitely the culprit. It amazes me all the cheap little components they put in such an amazing machine.
Quick Reply: Constant Buzzing behind Dash (Cluster)
