C6 Trailering tiedown
Cruising
I just purchased a 2007 C6 and I am going to be loading it in a car trailer
Any hints on tie down areas.There are slots in the frame behind the front wheels and in front of the back wheels.What are they meant for?Anyone know
You can use those slots, there are four of them, to tie down the car if the transport company has the right hardware. Many just use straps over the tires.
These slots are normally used for Jacking Pucks that attach by using the slots and create a jacking point. If you don't use these pucks or some other way of protecting your car, a typical tire shop (or many uneducated GM dealerships) will damage your rocker panels.
Congrats on the new car and welcome to the Forum. I hope you can get some miles in before the snow hits.
Not only can you use those slots, that's the real reason they're there. It's also where you lift the car from so jacking pucks were designed to fit into those slots, but the slots are there so the car can be tied down while on a trailer.
put T-hooks in the frame slots and tie to those
http://www.northerntool.com/webapp/w...70_43572_43572
CF Senior Member
I trailer my C6 almost weekly and IMO using the oval frame slots is the best way to secure the car. Assuming your tie-down points are compatible, get some heavy ratchet straps with the T-hooks, criss-cross the straps and ratchet each strap tight. Oh yea, make sure the ratchet straps have the flat snap-hooks so you can easily attach the t-hooks to the straps.
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
St. Jude Donor '09-'10
Cruising
Trailering C6
Thanks Guys I may do both I have to go 1600 miles I will check often to make sure they stay tight.
To Pylons:The slots are below the doors front and back.
Leaving at 6:00 am tomorrow my friend and i are going to switch off and drive straight through
