Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-01-2009, 05:37 PM   #1
FJONES96
CF Member
Send a message via ICQ to FJONES96
Default 1-4 Manual Shift Lock Out
This 1-4 First to Fourth Lock Out is kind of a pain. Does any one know how to shut this function off?
FJONES96 is offline   Reply With Quote
Old 11-01-2009, 05:39 PM   #2
ArcticLS3
CF Senior Member
ArcticLS3's Avatar
My solution: more right foot.
Other than that do a search for CAGS
ArcticLS3 is offline   Reply With Quote
Old 11-01-2009, 05:54 PM   #3
dkrhardy
CF Senior Member
dkrhardy's Avatar
When you do search, look at the fuse (blown) method. Simple, cheap, and works like a charm!
__________________
2012 Coupe, Supersonic Blue. The silver 'Vett was sold.
FAA CPC retired, US Navy retired
dkrhardy is offline   Reply With Quote
Old 11-01-2009, 05:55 PM   #4
N8sFavToy
CF Senior Member
N8sFavToy's Avatar
Send a message via AIM to N8sFavToy
Option 1 works for me . Hit it maybe once a month in heavy traffic.
N8sFavToy is offline   Reply With Quote
Old 11-01-2009, 05:57 PM   #5
JimTN
Moderator
Support Corvetteforum!
JimTN's Avatar
You can buy some hardware to by pass it (search on "CAGS eliminator") or you can put more foot into the throttle.
Quote:
One-to-Four Shift Light
This light will come on when:
• The engine coolant temperature is higher than
169°F (76°C),
• you are going 15 to 19 mph (24 to 31 km/h) and
• you are 21 percent throttle or less.
JimTN is offline   Reply With Quote
Old 11-01-2009, 05:59 PM   #6
johnodrake
Moderator
johnodrake's Avatar
Johnodrake @CdrDrake johnodrake
If you ever have your car tuned, you can have the tuner turn it off. Other than that, just drive around it.
__________________
Vita contin git. Vive com eo!
60th Anniversary 427 CE - Bone Stock.
MSM '06 415ci LS3 510rwhp, RPS, DeWitts, Pfadt Coilovers, MGW. Full 2012 GS body and interior conversion C6Z Exhaust
Spring Mountain x4
Leather by DSV
Powdercoating by Mike
DD 05 Silverado Z71
'89 Coupe - for Brody
Gone now but not forgotten:
Sebring Silver '97 LPE SC
Mille Miglia Red '73 L82 Coupe
Daytona Yellow '70 L46 Coupe
johnodrake is offline   Reply With Quote
Old 11-01-2009, 06:00 PM   #7
vettenut
CF Senior Member
KY Events Coordinator
vettenut's Avatar
Default skip shift
Get a CAGS eliminator from Mid America Corvette.. Easy installation (on a hoist) and works perfectly.
vettenut is offline   Reply With Quote
Old 11-01-2009, 06:00 PM   #8
ZPirate
CF Senior Member
ZPirate's Avatar
CAGS, pulling the fuse, or a tune. With a tune, like HP Tuners, you can turn it off and forget it. Oh and the right foot method works too. You just have to use it all the time.
ZPirate is offline   Reply With Quote
Old 11-01-2009, 06:02 PM   #9
Doing69
CF Senior Member
Doing69's Avatar
As others have said search on "CAGS eliminator" or "smart fuse"
I did the 1/4 watt 220 ohm resistor at the trans connector.
Doing69 is offline   Reply With Quote
Old 11-01-2009, 06:04 PM   #10
talionstallion21
CF Senior Member
talionstallion21's Avatar
I can't remember the last time the 1-4 skip shift kicked in on me. It never is a problem. Don't you just want to wind out first gear and bypass skip shift?, especially if you have NPP.
talionstallion21 is offline   Reply With Quote
Old 11-01-2009, 06:09 PM   #11
Rule292
CF Senior Member
St. Jude Donor '11-'12
Rule292's Avatar
Quote:
Yep!
At the top of the thread list is the "C6 FAQ's". There are several threads discussing how to bypass the CAGS (Computer Assisted Gear Selection) or "skip shift":
http://forums.corvetteforum.com/c6-c...tions-new.html
If you are handy with the soldering iron, you can do it for about 3 bucks. A blown fuse, a resistor, and some heat shrink tube.
Rule292 is offline   Reply With Quote
Old 11-01-2009, 07:39 PM   #12
carstocks
Junior Member
I got my CAGS eliminator from here:
http://www.pfyc.com/pc/VT6001/CMOTHE...?a_aid=froogle
Installs in 5 minutes. Works great, no error codes, and worth every penny. The dash will still light up "1-4" when the conditions are right for it, but it goes right into 2nd gear.
carstocks is offline   Reply With Quote
Old 11-01-2009, 08:43 PM   #13
tomzarbo
CF Senior Member
tomzarbo's Avatar
Default Not Always Trouble-Free
I got the CAGS Eliminator blown smare-fuse version $19.95 found on this forum and it worked for awhile. It ended up getting thrown out by the dealer and I replaced it with a $3.50 (for 2) smart fuse which I blew myself.
That worked for a month or so, then it started causing the check engine light to come on. It happened several times. I have a OBD2 scanner so I knew what the problem was. I replaced the blown smart fuse with a regular fuse, cleared the code, and no problems since.
Just so you know, the blown smart-fuse route may end up causing the check-engine light to come on, it has happened to others as well.
On some cars, it seems to work fine with no problems. Just thought you should know. I know I get a little nervous when my check engine light comes on and I don't want to get used to seeing it on.
TomZ
tomzarbo is offline   Reply With Quote
Old 11-01-2009, 09:22 PM   #14
Dave S
CF Senior Member
Dave S's Avatar
Any of the major Forum vendors sell CAGS Eliminators for $20 bucks.....easy DIY install & they work like a charm. I've had one in my '05 since new & never had a problem. Do a search on "CAGS Eliminator".
Dave S is offline   Reply With Quote
Old 11-01-2009, 10:36 PM   #15
bps999
CF Senior Member
bps999's Avatar
another vote for the rpm fix. After driving the car for awhile I realized the engine likes more rpm, and so do I. Now it never triggers the skip anymore.
bps999 is offline   Reply With Quote
Old 11-01-2009, 11:27 PM   #16
WMark
CF Senior Member
St. Jude Donor '11
WMark's Avatar
Quote:
I've lived it for seven years and two Corvettes. Didn't take long to learn to drive without worrying about it. All you have to hit is 2k RPM. Okay. Few occasions, mostly left turn lanes, I miss the beat. Overall, I don't remember it as an issue!
Drive it like you stole it!
WMark is offline   Reply With Quote
Old 11-01-2009, 11:30 PM   #17
Dave Tracy
CF Senior Member
Quote:
Or ramps!
Dave Tracy is offline   Reply With Quote
Old 11-02-2009, 12:53 AM   #18
ez2spd
CF Senior Member
ez2spd's Avatar
"CAGS eliminator" and a jack with stands and call it a day!!
ez2spd is offline   Reply With Quote
Reload this Page 1-4 Manual Shift Lock Out
Tags
14, bypass, c4, c6, corvette, corvettes, fuse, kit, lock, lockout, shift, shifter, skip, trans, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1 to 4 skip shift -- STOP!! cicch95 C4 General Discussion 24 07-13-2003 09:16 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
