Is 205 Degrees Too Hot?
205 degrees for your water temp, at highway speed, is normal. They run hotter than the C5's. Even in colder weather I don't see temps lower than 199 degrees while on the highway.
I normally run bewteen 195 and 205 in light cruising (freeway speeds with light throttle). It sometimes runs as high as 215-220 when in very heavy trraffic on warmer days when running at low speeds, but drops to around 200-205 once I am rolling again. Your temps sound absolutely normal. BTW, I have an '08 base 1LT with the A6.
205 is spot on for the coolant temperature at highway speeds. Whether it is 75 or 95 degrees ambient, that's the temperature I always see when driving from TX to LA or vice versa.
Received 8,958 Likes
If you want an under hood light GM Accessory Part Number 19165567 is available from Gene Culley for $32.20 + Shipping.
http://www.gmpartshouseusa.com/partl...subcat2=132697
Bill
Bill
Received 2,057 Likes
St. Jude Donor '13
Hmmm...
Cruising at highway speeds in temps arouond 70'F, my coolant runs 196' like a rock.
Straight cruising when outside air temps are normal, I run at 192-194. Stop and go can go to 205 even higher. I have a '07, Z51/manual trans. If A/C is on, the fans will automatically stay on but shut down over 35mph (I think that's the speed), so temps can actually run cooler with A/C on because of that.
The under hood light was omitted in '07.
#33
Driving thru N Arizona on my way to Page from North rim of Grand Canyon this summer it was 100 F outside at 10 PM at Marble Canyon, water temp was 199, which is 1 degree warmer than it normally is. Once it warms up to 198, only a traffic jam makes it go higher.
