C6 Comprehensive Fob Programming Instructions
#361
My whirl didn't whirl, nothing happened after I did the 5 twists with the fob key( does it make a difference which key u use) the DIC didn't light at all and I tried a couple of times. After failing I just took my fob and put in the slot and the car started but I don't think that proved anything because the fob is in the car. Should I increase my Ginko Biloba?
#362
#363
Fob
I will keep on keepin on.
#364
FOB Slot check
I worked as described. My issue was that my C-6 has been sitting for a while so after I started it and shut it back down everything fell into place. Oh, I and also discovered that the guy I purchased the car from owes me another FOB I have one and three. Thanks again CFer's.
Another test of the slot is to put a good fob in the slot with no battery in it. Many but not all C6s will recognize a fob with no battery. This would prove that the fob is being recognized by the slot itself and not just the car as normal. I have tried putting just the one half of my fobs in the slot, without the half that contains the battery and the car sees them fine. It is not definitive in a negative way though because not all C6s will see a fob in the slot without its' battery, even though everything is working fine. So if it works, it proves the positive but if it doesn't work, it does not prove the negative. Read through the entire thread (I know it's long) and try the many tips people have given from their experience. Getting the car into the program mode is certainly the most common problem with the system.
#366
I'm not aware of a situation here where the procedure was properly followed, including most importantly the testing of the glovebox slot, that resulted in the bricking of the car. I may be wrong, it may have happened, but I'm not aware of any instances of it.
#367
Navigator
Yeah, I tried a zillion times without success, but then it clicked in and voila, works great. Thanks for the pointer RicK T. And thanks you very much for the guidance CClive. Great job!
#368
The long procedure worked perfect the first time for my '08.
I had lost my #2 FOB several years ago. Then recently my #1 FOB went through the washer. I tried to get it to work but I couldn't open either door. I had to manually open through trunk.
I tried my old FOB in the glove box slot and the car started, but still wouldn't recognize FOB when it was removed. I tried changing the battery and still no luck.
I was resigned to have the car transported to the dealer, but then I found this thread. I then purchased 2 new FOBs with blank keys and viola, I now have two functioning FOBs. Thanks to everyone who has contributed to this thread.
Brad
Brad
#370
After a good 2 hrs, maybe more I finally got this to work.
I have 2006 c6 z06. While trying to program the new key fob (08 style) I simply could not the get DIC to initialize.
After reading all the tricks and tips I was about to give up.
I tried everything...
-doors open/closed
-glove open/closed
-key fob in cup holder/center console/in glove compartment
-tried running to the back of the car as quickly as possible
-opened rear carpet and pulled trunk cable manually.
You name it, I was about to start rubbing the top of my head and hopping on one foot if that was the next tip that may have worked.
I read a few guys here saying try reverse.
We'll I tried that initially and it didn't work.
I guess I wasn't in reverse far enough though.
So here is what worked from start to finish.
- mechanical key ready in trunk slot
-Trunk open fully
-open door
-key fob cup holder
-vehicle to on (no engine)
-e brake down
-reverse gear (be sure you are fully in reverse I depressed clutch and made sure the vehicle was securely in reverse).
- e brake back up
- car off (bottom left of start button)
- ran to trunk and turned 5 full times
Some of these steps may not have been important but try them anyway, the most important is being in reverse fully.
I hope this helps someone and thanks again for all the tips in here I was literally going to throw in the towel if that last procedure didn't work this one last time
-doors open/closed
-glove open/closed
-Trunk open fully
-open door
-key fob cup holder
-e brake down
- e brake back up
#371
-Trunk open fully
-open door
-key fob cup holder
-e brake down
- e brake back up
#372
I think this is an early model 05-09 manual or z06 issue but at any rate if someone is having trouble it's worth a shot, just don't forget the parking brake!
#373
Neither FOB working
The instructions seem simple enough but my problem is both the original FOBS #1 and #2 will not remotely start the car. The only way I can start the car is to open the glove box and place either one in the FOB slot. I took the FOB's to the dealer and they tested them on their receiving unit. Neither one could send a signal even with a new battery.
My question is "What is my starting point in this situation".
Thanks.
Thanks.
#374
Went to the dealer today, took them 15 minutes and cost me $25.
Honestly, no I didn't read all 17 pages. I tried probably 5 or so methods 3-5 times each. It's 100+ degrees everyday where I live and I would be drenched with sweat each time I tried a new method. I just reached my boiling point (pun intended). If I knew it was going to be that easy/cheap, I would've went to the dealer first.
Like, you I read a good majority of this post, with nothing but no luck and a lot of frustration.
I took my car and FOB's to the dealer. They got them both programmed for $55.00. Yup, $55.00....But at least, they're both working.
Thank you everyone for such a comprehensive post......
#375
Thanks.
Thanks.
If not, then it is likely the fob batteries. I would put absolutely no stock in the dealers "receiving unit". If the car does respond to the buttons but does not start with a fob in the car (and it's both fobs), then I would start investigating interference from chargers, cellphones or any other accessories. While it is possible, it is highly unlikely that both of your fobs have gone bad. They are extremely simple solid state devices with not much to go wrong. The biggest problem that people have with fobs not working is batteries...either dead or not replaced correctly. Unless both of your fobs have been washed, I wouldn't believe that both have gone bad. Many that have been washed have continued to work fine anyway.
#376
No mention of the key.....does the key stay in the trunk slot after the five turns or can you pull it out? I get all the way to the end where it says Ready For Fob 1, put in the Fob into the glove slot and than NOTHING! So frustrated, spent four hours trying to get this long procedure done.
#377
Was thinking of having it towed to the dealer and having them program it now, but how do i get it towed if the wheel is locked and it's stuck in park due to not being able to "put the key in the ignition" so to speak?
#378
In none of the threads does it mention anything about when programming the FOB to have the top pointed in. My assumption was the bottom went in first since it looks like it can be programmed via the connection inside the bottom when the key blade is pulled out, however that is not the case. Put it in with bottom pointing out and buttons to the right and it worked the first time. Can't believe that isn't in any of the programing instructions. Read umpteen messages trying to figure out what I was doing wrong and none had this clue. WOW....thanks Fort Morgan!
#379
Amen to this!!!!! End where key goes in points out of slot!
THANK YOU, Corvette 505!!!!
PS: found FOB 2 so now have 3. In the end, all is OK as it is good to have a backup.
#380
I guess that when I wrote the instructions, it never occurred to me that the fob could be put in backwards because I figured most people have other keys attached to the end with the ring on it, so it wouldn't go in the slot that way. I'll add a note to the instructions to that effect...hopefully saving some people some time...LOL
