Nitto Invo Tires
Nitto Invo Tires
Anyone running this combination of Nitto Invos?
255/35/18 front
305/30/19 rear
I'm putting down 542 RWHP 482 RWTQ
The Toyo Proxes T1 R are not holding to the ground with my C6 A4 tranny.
So I'm thinking of going to the set up mentioned above and would like to know if anyone has that setup and how is it working for them.
255/35/18 front
305/30/19 rear
I have a set of Invos, but honestly, if the T1's aren't holding as well as you'd like, the Invos aren't going to be that much better. The Invos grip well, but I would probably go with a higher end tire with the amount of power you're putting down.
OK, Anyone running Hankook evos
255/35/R18
305/30/19
If so, how do you like em and do you think they will out perform the Toyo Proxes T 1s I now have?
Thanks,
255/35/R18
305/30/19
Thanks,
