sagging door?
8th Gear
sagging door?
Anyone have trouble with doors sagging?
My driver's door sagged just a bit and before i realized that it made a very small chip in the paint. Off to the shop it goes...ASAP. Just curious though, if this happens to others?
I didn't have any problem with mine, actually the door fitment is amazingly aligned (I always check ever since my Z28 which had doors that were slightly off), I'd be surprised to hear that this is a common problem, I think if it's aligned when new it would stay that way...
good luck!
did you buy the car new?
good luck!
good luck!
First I've heard of this on any Corvette newer than about a 1970....seems odd that would happen to you. Good luck getting it repaired and let us know how it goes and what they say.
2nd Gear
I have this issue too, is there a kit to replace the bushings in the door hinge? I do not have this issue with the passenge door but I only use that side a fraction of the time I use the driver's door. I would rather not pay dealer prices for some kid that has never worked on a corvette before to take care of my baby.
I have a variation of this. My driver door make a slight clunk when I open it at about the 3/4 position. it is'11 with 3k, I'm thinking it's about a three trip to the dealer before they say it is Normal. Is it me, too particular?
I have a 2011 c6 base. Bought brand new almost a year ago. My drivers door is sagging a bit and doesnt close cleanly anymore. I'm taking it to the dealer at the end of the month to have it looked at.
The only time I have ever heard/seen of a car door sagging- it means either the screws have backed out of the hinge that connects it to the frame or the hinge pins are broken. Usually the top pin breaks.
I'm a bit late responding to this stream, but has anyone with the sagging door issue also had issue with the window not fitting in the channel correctly? I know its not the indexing issue, but the widow does seem to fit the clear door a lot better than the solid roof.
Received 1,675 Likes
First I've heard of it.
