is there a by pass to drop the top while moving
Old 08-19-2009, 01:53 PM
wcrmltd
wcrmltd's Avatar
Default is there a by pass to drop the top while moving
When I had a Porsche convertible i did a electrical mod that would allow you to be moving at slow speed and the top still complete the up or down movement. You could start it going down or up while stopped and move slow so the wind would not cause an issue and it would complete the movement. The Corvette top on the 2008 will not work either if not stopped in park. Is there a mod to changed this?
Old 08-19-2009, 01:56 PM
cclive
cclive's Avatar
Very simple, just pull the handbrake up one click....its not enough to actually activate the brake, but it tells the computer that its OK to move the top. I used it to put the top up and down in heavy freeway traffic when I was in LA...gets fun looks from people...
Mine is a manual trans....so the trans is not part of the equation...don't know about an auto...
Old 08-19-2009, 02:03 PM
VettedCandidate
VettedCandidate's Avatar
Hey let me know how that works and if you have any problems with it. I'd be worried abut the frame getting a bit out of whack.
Old 08-19-2009, 02:04 PM
ZO6 Lee
Support Corvetteforum!
ZO6 Lee's Avatar
St. Jude Donor '08-'09-'10
Very interesting. I too, set it up on my Porsche but didn't think I could do it on the Vette. Heading out to try it.
Thanks for the idea.
Old 08-19-2009, 02:05 PM
wcrmltd
wcrmltd's Avatar
Thanks what is the normal requirement to lower the top on the manual. if it requires that the handbrake be on then i see how this would work but it is not a requirement for the auto. Park and there is not a partial thing i can do with this action. unless i hear from someone else on a different fix i will try this just to see. Thanks again.
Old 08-19-2009, 02:09 PM
wcrmltd
wcrmltd's Avatar
i understand and i never was moving over 5 miles per hour or very slow to do this on the Porsche and would keep speed down to same with Corvette.
Old 08-19-2009, 02:14 PM
wcrmltd
wcrmltd's Avatar
Well it does work even on auto. I put the car in drive and one small pull on handbrake and it let it move up or down. Thanks.
Old 08-19-2009, 02:15 PM
cclive
cclive's Avatar
On the manual, the DIC will tell you to apply the parking brake when you push the button for the top. The parking brake is the key....gear does not matter. This works great when just rolling...maybe 15mph max...
Nice to know it works on auto trans also! And one click on the parking brake isn't enough to be a problem there at 15mph for a couple of hundred feet...
Old 08-19-2009, 02:34 PM
obxchartercaptain
obxchartercaptain's Avatar
FL Events Coordinator
ANOTHER reason why this forum is such a GREAT place for info. Thanks Guys ..... I will use this ALOT.
Old 08-19-2009, 02:57 PM
spinalator
spinalator's Avatar
Wow. Great info. I had no idea... Thanks
Old 08-19-2009, 03:01 PM
Road Rage
Road Rage's Avatar
Right now that scene in Cast Away with Tom Hanks comes to mind. When the "sail" he rigged up to get off the island flew away during the storm.
Old 08-19-2009, 03:09 PM
drich2905
drich2905's Avatar
nice to know-will try mine tonight. Even though I may never use it I have had occasion to be in slow traffic and it started to rain (does that with sunny skies here in south Ga. afternoons). Sure will be nice to be putting the top up during a slow roll.
Old 08-19-2009, 03:12 PM
RadarP3C
RadarP3C's Avatar
Yes, and check out one of the first scenes in the latest Star Trek movie with a young JT Kirk driving a convertible corvette....
Old 08-19-2009, 03:14 PM
cclive
cclive's Avatar
Or at a stoplight where you don't quite get the top moved all the way before it turns green......
Old 08-19-2009, 03:21 PM
LarryMJones
LarryMJones's Avatar
St. Jude Donor '13-'14-'15-'16-'17
There are a few aviators and X aviators on here that might misinterpet the phrase 'putting the top up during a slow roll'.
I wouldn't recommend slow rolling a vette. The fuel system is not rated for inverted flight of any duration.
LJ lol lol lol
Old 08-19-2009, 03:40 PM
DJ-LO
DJ-LO's Avatar
That's why you make sure you have about 18 seconds to complete the move! And I don't think anyone is going to try this at highway speeds!
Old 08-19-2009, 03:45 PM
06 C6 vert
06 C6 vert's Avatar
Hey does anyone know how to put the manual top up while moving?
To is there a by pass to drop the top while moving
Old 08-19-2009, 03:58 PM
cclive
cclive's Avatar
Wife running alongside.......
Old 08-19-2009, 04:07 PM
bigsteff
bigsteff's Avatar
Some mods should be thought of but not acted upon !!!!
Old 08-19-2009, 04:14 PM
george vee
george vee's Avatar
Received 1,074 Likes on 532 Posts
2015 C7 of the Year Finalist
Thanks I'll try it tonight.
Quick Reply: is there a by pass to drop the top while moving
