Mobil 1 vs Castrol Edge (8 x better)?
Old 08-15-2009, 09:08 PM
Rocketmanwpb
Rocketmanwpb's Avatar
I'm sure all the oils are good, but I have never heard of a vette engine blowing up because it used Mobile 1.
Old 08-16-2009, 01:01 AM
Rule292
Rule292's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16
Originally Posted by Jaxon
What evidence do you have that Mobil pays GM to use their oil?
The fact of the matter is the consumer does not have enough data to make an intelligent decision about what oil to use. The oil spec that a car manufacturer suggests meets the requirement for the needs of that engine. Things like gasket material, aluminum or alloys vs. steel engine components, RPM range, bearing clearances and size, tolerances between parts, operating temps, thermal expansion of engine components, etc. Just because an oil manufacturer says it is 8X better in one catagory that doesn't mean it is a better oil for your application. Use any oil that meets the spec suggested by the manufacturer and you will be fine. The guys with the lab coats have all of the data, you don't.
Hard to argue with your logic. It's not like you can actually see the difference between oils
Truth of the matter is, as soon as Wal-mart's super cheap Super Tech synthetic shows up on the shelves being 4718M certified, it's just as good as M1 or Castrol or Amsoil. And it meets the powertrain and emissions warranties.
Old 08-16-2009, 01:24 AM
Jedsvet
Jedsvet's Avatar
4718M is all that matters to me. nothing less. one thing that 4718M takes in consideration is heat. dyno oils cannot handle it. 4718M can.
Old 08-16-2009, 01:55 AM
4thC4at60
4thC4at60's Avatar
Received 2,921 Likes on 1,302 Posts
Originally Posted by bksnoopy
I watched the video that was an ad banner here on the forum website. 8X better is what I would say a big improvement. What do you guys think?
I watched it with an open mind and they did a good job beating down Mobil 1.
<snip>
I have 500,000+ miles in Corvettes using Mobil 1. Two of my former four Corvettes (C4s), each with nearly 200,000 miles on them when I sold them, now have in excess of 300,000 miles each. One is living happily in Austin, Texas, the other in Paris, Texas.
Can you imagine? Had I used Castrol those same Vettes would last about 1.6 million miles. Why oh why didn't I use Castrol?
Old 08-16-2009, 11:28 AM
FredC7
Support Corvetteforum!
FredC7's Avatar
I have always used Mobil 1 5W-30 as recommended by the manufacturer. However the 5 qt Mobil 1 at $22.00 in Walmart always seems to be out of stock so I am about to try the new Mobil 1 AFE (Advanced Fuel Economy), that comes in 0W-30 viscosity. The Mobil 1 website and the bottle both say that it is 4718M certified and meets or exceeds that standard. The $10 coupon for Mobil 1 is no longer available but there is a $10 rebate on the www.mobiloil.com website available after you take the quiz to see how much they say that you will save per year by switching to the new AFE oil.
Old 08-16-2009, 11:46 AM
Rogers 07
Rogers 07's Avatar
[QUOTE=4thC4at60;1571154415]
<snip>
Damn, I hate it when that happens !!!!!!
Old 08-16-2009, 12:21 PM
quickc6
quickc6's Avatar
Old 08-16-2009, 01:12 PM
wbear
wbear's Avatar
I'm with ya Fred.
0w-30 is the way to go. Same high temp protection as 5w-30 but faster start up lubrication where most wear takes place. Even in say, Miami Beach.
I'll go out on a limb and say before too long 0w-30 will be the factory fill and recommended oil in Vettes.
Old 08-16-2009, 03:21 PM
Gearhead Jim
Gearhead Jim's Avatar
Received 2,051 Likes on 1,362 Posts
St. Jude Donor '13
GM could deny a warranty claim if you are not using at oil that is both 4718M and 5W-30. They've been getting pretty picky about warranty issues recently and who wants to spend the money to fight it out in court.
If you're not under warranty, 'nuther story.
Old 08-16-2009, 03:23 PM
Gearhead Jim
St. Jude Donor '13
Old 08-16-2009, 03:34 PM
GotVett?
GotVett?'s Avatar
I like the way Mobil 1 looks.
Toys4Life C5 (07-09-2022)
Old 08-16-2009, 08:04 PM
Tulsa Vette Guy
Tulsa Vette Guy's Avatar
Default synthetic
At what mileage should it be safe to start using synthetics. The rings need to be seated.I have been told??
Old 08-16-2009, 08:25 PM
  #33
Patman
Patman's Avatar
Received 1,919 Likes on 1,191 Posts
You can use it from day one, and GM tends to agree since that's been the factory fill in all Vettes since 1992. Rings will still seat perfectly fine even if synthetic oil is used for the initial fill.
Old 08-16-2009, 08:30 PM
  #34
C-INRED
C-INRED's Avatar
St. Jude Donor '06
I love these oil threads!
Old 08-16-2009, 10:01 PM
  #35
Rogers 07
Rogers 07's Avatar
We havent had a really good squeaking top or Z-51 badge thread in a while either.....
Old 08-16-2009, 11:49 PM
  #36
cclive
cclive's Avatar
I like badges....
Old 08-17-2009, 12:08 AM
  #37
TEXHAWK0
TEXHAWK0's Avatar
The Mobil 1 bottles I have read recently do not say they meet the GM 4718M spec, while Castol EDGE, Valvoline Synpower, and Quaker State synthetic do list the spec.
Castrol and Valvoline both claim they provide better wear protection than Mobil 1, and technically Mobil 1 does not even pass the wear test.
To Mobil 1 vs Castrol Edge (8 x better)?
Old 08-17-2009, 12:25 AM
  #38
Dueysan
Dueysan's Avatar
Originally Posted by skierhc
after watching several teams put Mobil 1 in the Indy Cars at Texas Motorspeedway, I figured it was good enough for my Corvette
Originally Posted by calaher
Mobil 1 is also the standard with NASCAR.
Do you guys rebuild your engines after every race too?
Nothing wrong with Mobil 1 but I would never base a decision on what a race team with a relatively unlimited racing budget (compared to a weekend racer) advertises and/or puts in their race cars.
Old 08-17-2009, 07:16 AM
  #39
EuroRod
EuroRod's Avatar
Originally Posted by Easy Rhino
Never had any car engine fail due to the selection of the oil used, in over 40 years of owning and driving cars.
Not saying that you should use vegetable oil, just sayin' . . . .
That's a good point. Neither have I. And, my 1994 F-250 went 357k miles before I sold it, and the engine was still very soild with zero oil consumption. (Really wish I still had that ol'rust beater, too!)
Old 08-17-2009, 07:35 AM
  #40
2xmks
2xmks's Avatar
I run Mobil 1 in my vette. I ran Castrol in my track car. I've had no issues with either. In the end, my personal opinion is that in either case we are all gonna be just fine.
(But you know what they say about oninions )
Quick Reply: Mobil 1 vs Castrol Edge (8 x better)?
