changing the turn signal?
Old 07-18-2009, 10:31 AM
mikez51c6
mikez51c6's Avatar
St. Jude Donor '11
Default changing the turn signal?
Anyone tell me how hard this is to do? I have a 05 bought it used didnt come with a manual and tried a search couldnt find what i need
Old 07-18-2009, 10:34 AM
dpigguy
dpigguy's Avatar
You can download the 05 OM by going to the FAQ C6 "sticky" at the top of the forum home page and looking under Owners Manuals. In there your will find what you are looking for. good luck!
Old 07-18-2009, 10:35 AM
Zymurgy
Moderator
Support Corvetteforum!
Zymurgy's Avatar
Received 15,075 Likes on 6,173 Posts
From the owners manual:
To replace a high-beam or front parking/turn signal/DRL
bulb, do the following:
1. Turn the wheel to allow access to the wheel well.
2. Access the high-beam or front parking/turn signal
bulbs by removing the access panel. To do this,
remove the three outer fasteners and flip back
the cover.
3. Remove the outer cover to expose the high-beam
headlamp bulb socket once the access cover has
been removed.
4. Remove the headlamp
bulb by releasing the
outer tabs from
the socket.
5. Remove the front parking/turn signal bulb by turning
the bulb socket counterclockwise.
6. Replace the high-beam headlamp bulb with a new
bulb and reattach to the bulb socket.
Replace the front parking/turn signal bulb by turning
the bulb socket clockwise.
7. Reverse the Steps 2 through 4 to reinstall.
Old 07-18-2009, 10:37 AM
Zymurgy
Moderator
Zymurgy's Avatar
Here is what it looks like with a few of the fastener pins removed and the cover "flipped back":
mikez51c6
mikez51c6's Avatar
St. Jude Donor '11
Thanx guys
Old 07-18-2009, 11:27 AM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
I'm sure it's easier to change the turn signal BULB, rather than the turn signal itself.
I suspect that's what you meant.
Old 07-18-2009, 12:28 PM
mikez51c6
mikez51c6's Avatar
St. Jude Donor '11
Yep thats what I did not as bad as i thought would have been easier with tire off but its done now was hard to sleep last night thinking about that damn bulb but my baby is complete again
To changing the turn signal?
Quick Reply: changing the turn signal?
