What could have/should have been done better in the C6?
I troll the forum all the time and I haven't seen this come up in awhile so I thought I'd ask. What would you like to have seen engineered better in the C6?
I'm not talking about upgrades like Z06 brakes or anything like that. Just what could have been done better with what comes on a C6.
While I love my 06 coupe, here's my list:
1. Front license plate. When I had my C5, I finally caved in and installed the front plate. To make it look better, I bought a color matched surround. After awhile I actually liked the look, thought it was well laid out. No such luck on the C6. Factory mount looks clunky and even the $150 aftermarket replacements make the car look bucktoothed.
2. Nav System. Unlike some on this board, I actually like it and the Bose. I don't care about watching DVDs or backup cameras, etc. A few things could been done better though. For one thing it's not bright enough, gets washed out in the sunlight too easy, no matter how the brightness or contrast is adjusted. Also, XM volume is too low, hard to hear on the highway with the top off. Finally, no input jack. I bought a Lockpick which works fine with my iPod, but come on, I shouldn't have had to.
3. Clutch assist spring. Hated driving the car with it, was considering trading for automatic and finally bit the bullet and took it out. MUCH better now. Consistent feel, don't look like a noob now when the light changes unexpectedly and I no longer drop the clutch and kill the car due to the uneven pressure.
4. Flimsy Backside. When I first got the car, I thought there was something missing behind the fiberglass. It pushed in too easy, seemed wobbly. Then I checked the other vettes on the lot and they were the same. Don't remember the same degree of squishiness on my old C5.
5. No longer can see trouble codes on DIC. I loved this feature on the C5. I know one can use a code reader, but it was quite handy to have it built in.
6. Lame Exhaust Note. I like everyone else on here has either swapped my exhaust or will in search of a sound more worthy of the Corvette. But again, I shouldn't have to. A friend of mine with his LS1 Goat has a terrific sounding factory system. We don't.
7. Honorable Mention. On my C5, the Window Valet had an option to play the radio with doors open, no chime. Apparently this isn't possible with the C6. Have to trip the door latch in accessory mode to stop the chime. Too bad.
So what bugs you all?
I wish they would have kept the key for the ignition.
I wish they would have kept the regular door handles no electric
door.
I wish they would bring back a spare tire, I dont like run-flats.
To much electric crap to run down the battery.
door.
AngelS3 (04-25-2023)
Don't get me wrong. I love my '05 vert but I would like to see a few changes (some that probably already happened):
- DBS/battery, electrical hog issues
- Need better run-flat tires
- Better shifter standard
- Better-sounding muffler standard
- Teflon paint so I don't have to wash it as often!
With regard to any specific component, it is always possible that there will be a better part out there someplace. Therefore, I will not voice a complaint about any single item because overall I am very pleased with the way the compromises have been made in the Vette.
That said, the number one complaint that you named -- lack of a properly designed in front license plate mounting -- is my number one complaint. This is a design issue, not a component issue in my mind. A considerable majority of states require both plates. Every generation a Vettes prior to the C6 has not only addressed this, but has done it well and better than most cars in the market place. That my .02
1-NPP Should be standard on all C6's.
2-The seats should have better quality leather. (The seats are fine for me, but my seat leather is now in GM VIS as being defective from the factory. Also the seats tear too easily, terrible quality.)
3-The car should have an air lift suspension to prevent scraping going up a drive way.
4-The car should have a different steering wheel, the current one is used in too many current Chevy's.
5-The automatic transmission paddle shifting should be tuned similar to how Chuck COW tunes them.
6-The Front of the car should have been designed to accommodate a front License Plate.
7- The stereo should be about 100 Watts stronger.
Moderator
Received 3,589 Likes
I think they did a good job. Anything that was a 'better' item would have cost more, weighed more, or been a item that another would not have liked.
They should have set the engine mapping/tune up stronger. Also cold/ ram air coming thru a high enuf duct. Better tires even they have shorter warranty. Better insulation. Optional sub. HUD,and side air bags should be safety standard
Those are all good suggestions. I would put the front license plate mount at the top of my 'wish list' for fixes on the next generation. Hard to believe it actually made production this way knowing so many states require a front plate. The factory mount is horrible and even the best aftermarket ones are a compromise to appearance.
FRC body style
Better shaped seats with micro suede standard,and let the cheap crappy leather be an option
Sportier steering wheel,with micro suede
Full color interior(dash,door panels,carpet etc. all match)
Match the gas and dead pedal, like clutch and brake
Wow, good points all! I would have traded the keyless ignition and electronic door latches for better exhaust and improvements in the Nav/Stereo if it were possible.
A couple of more simple items I thought of:
- I miss having flip up wipers like most cars nowadays. Makes detailing the windshield easier, changing blades, etc.
- It would have been good to offer factory tinting for the rear hatch (or rear windows for verts). Now if we want it, we have to find a tinter that can deal with those dots.
Still, I don't want to come across as whining - only mean it as constructive criticism. I love my C6!
