Has anyone experinced
Location: ,fl.Never, under any circumstances, take a sleeping pill and a laxative on the same night.
Has anyone experinced peebles,rocks,etc.. in your front cover in the wheel well
I dont know if anyone has come up with a diy fix for this pesty problem,I tried my own so far and it seems to work just fine,all I did was basically get some weather stripping foam 3/8 one side adhesive and start by placing the foam between inside liner and the actual finished quaterpanel here are some pics along the way...start here and work your way toward the front applying dish soap to the adhesive side makes installing the tape a little easier,hope this helps anyone
Good idea and nice DIY. Thanks.
Here is another one you will probably need to address, if you haven't already, just a different place:
http://www.nakidparts.com/id22.html
Why yes I did, verry helpful,and I says to myself.....self how do we stop this from happening in the front, so far it seems to work
