NPP Exhaust Stuck Open?
I took a low speed offroad excursion due to a combination of inattention on my part and a large white SUV deciding they needed my lane; had some large rocks bounce off the undercarriage of the passenger side. Everything is fixable, no one hurt, but for some reason my stock NPP is staying open.
I checked vacuum lines to make sure none had been knocked off, but could not find anything. No Codes or Warnings on the DIC, checked the fuse, car runs fine.
Any suggestions?
Any suggestions?
Location: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
1 Post
Pull the vacum lines off at the actuaters and take a vacum reading. I'm guessing its O.
Let us know what you find.
Or its a blown fuse, but I dought it.
Here is a link with some exploded parts drawings that might help with locating possible disconnects of either the vacuum lines or possible the solenoid wiring..Good luck...http://forums.corvetteforum.com/c6-t...tterflies.html
Former Vendor
St. Jude Donor '09
First step is simple, assuming you have the stock fuse in the exhaust spot and the car running, just pull off one of the vacuum lines and see if you have vacuum. Here is a clear shot of where the line attaches to the actuator (yours line will be slightly different but attach in the same spot)
I doubt you will have any vacuum (checking with a gauge would be best should have 14-18 HG), if you do, the actuator is damaged. If not, you either have damage to the vacuum line from the motor to the back (unlikely IMO since they are tucked away) or the solenoid located on the rear bumper support was damaged or the wires to it could have been damaged
Happy to help anyway I can
FL Events Coordinator
Former Vendor
St. Jude Donor '09
Thank you nwc6 and SonOfDreams, great info, will get to it Monday I think, a working weekend right now, and as the CudjoeScott says, it is sort of an enjoyable problem. Mainly wondered why there were no codes thrown.
Will post what is eventually found. Still under warranty and good insurance, so whatever comes up will be covered...
Former Vendor
St. Jude Donor '09
Sure sopunds like a vacuum leak to me...
Better check sooner rather than later as dirt may be being sucked into the engine at the leak point...there is no inline filter nor excess flow check in the GM design I do not believe...although a vacuum leak will usually set a trouble code...
Good luck. First step is check for vacuum at actuators.
