Lost Cruise Control After Parade
Had my 2007 AO Coupe in the Memorial Day Parade here in Fort Wayne. In that my water temp. got to 221 deg., I occasionally shifted to neutral & gunned the engine. The day after the parade, I noticed that my Cruise Control was not working. Thanks to this forum, I read that disconnecting the battery for 5 minutes should bring back the Cruise Control. It did. Apparently, high rpm's shuts down the Cruise Control. I don't know what else would have caused this issue.
Jim
Jim
Wounded Warrior Escort '11
If you have a manual tranny, take a look at the clutch switch...auto, I have no clue. The cruise is totally electronic. If you have a code reader, I would pull the codes.
And since the fan is electric and is not run mechanically off the engine like most cars, revving it during a parade or heavy traffic won't help anything.
St. Jude Donor '13-'14-'15-'16-'17
Not 100%
Water side equation radiator cooling effect
BTU rejected = 500 x gpm x (t1 water in - t2 water out)
Air side equation radiator cooling effect
BTU rejected = CFM x 1.08 x (t1 air in - t2 air out)
t in farenheit
Yoy really don't know if the water flow or air flow is causing the overheating.
LJ
Seems like a lose/lose situation to me.
Yes air flow is fixed with electric fans. And increasing water flow will increase radiator cooloing capacity with constant airflow.
Big question is how much heat do you add by just reving the engine. Your not really producing much more horsepower with no load on the engine(just internal friction losses), so the increased water flow may actually help.
Really not sufficient data to tell. Good therotical question for friday afternoon.
LJ
LJ
I agree about the water pump.....but I don't agree with using the word "overheating".....221 degrees is perfectly acceptable on a hot day going slowly in a parade in a humid place. The OP should have been able to hear the fan clearly during the parade if it was working properly, so this would be my first question to him.
