Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-25-2009, 06:11 PM   #1
sunsetdaytona
Junior Member
Default Corvette won't start, but battery OK !
Have '05 corvette. Went to start it the other day and acted like battery was dead. But then the horn started beeping so I unhooked battery cable to stop it. When I put cable back on, the horn beeping starts again, but all else on battery power won't work. Can't open doors, etc. Motor won't crank at all. Anyone else had this problem?
sunsetdaytona is offline   Reply With Quote
Old 05-25-2009, 06:47 PM   #2
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Support Corvetteforum!
talon90's Avatar
Quote:
Describe what you mean by "acted like battery was dead" and tell us why you think that battery is ok.
Having a little power in the batter (less than 11.3 volts) may power the lights, open the doors and honk the horn, but won't be enough power to start the car.
talon90 is offline   Reply With Quote
Old 05-25-2009, 06:56 PM   #3
corvettezman
CF Senior Member
St. Jude Donor '11-'12-'13
corvettezman's Avatar
Location: God's country, home of the VOLS ! Knoxville, TN. Tennessee
When my body control module went south, my car acted in the same fashion, however I smelled something burning in mine , and the car acted like it was possessed, the windows started rolling up and down on their own, trunk opened by itself, horn started blowing, etc.... and the car would not start either.
corvettezman is offline   Reply With Quote
Old 05-25-2009, 06:56 PM   #4
VET4LES
CF Senior Member
VET4LES's Avatar
Sounds like it's time to replace your battery. My original died in 22 months.
VET4LES is offline   Reply With Quote
Old 05-25-2009, 07:16 PM   #5
0Stainless Addiction
Former Vendor
If it is an automatic check to make sure it's in park all the way. That's what my car did once.
Stainless Addiction is offline   Reply With Quote
Old 05-25-2009, 07:16 PM   #6
sunsetdaytona
Junior Member
when I tried to start my vette, it didn't do anything, so at first I thought battery was dead. Then the info screen said that it did not detect the fob and I noticed the check engine light was on. Fob message went off, but car still dead. Then when I pushed the start button again, I get a faint beep, beep, beep, continously but all electrical system is not working. I unhooked the battery cable to stop the horn beeping. After a while, I put cable back on, horn sounded real loud, a constant blare of the horn. Door still wouldn't open, I had to open it manually. When I pushed the start button again, same thing, a slight constant beep, beep, beep of the horn. I did change the battery in the fob, but that wasn't the problem. I assume that since the horn honked real loud when I first hooked the battery cable back on, that the battery was OK. Could it just be the battery?
Old 05-25-2009, 07:19 PM   #7
cclive
CF Senior Member
cclive's Avatar
Those symptoms are indicative of a bad or low battery. Just honking the horn does not mean that the battery is OK. With a meter, check the voltage at the battery when all this is happening, and if it is less than about 11 volts, the problems are being caused by the low voltage.....meaning the battery needs to be charged, or if it won't hold a charge, then replaced.
Low voltage can cause all the electronics to go crazy....fobs, DIC, doors, trunk, etc,etc.
cclive is offline   Reply With Quote
Old 05-25-2009, 07:19 PM   #8
sunsetdaytona
Junior Member
Quote:
mine hasn't done wierd things like that, just all electrical is dead, doors won't open, but when I hook the battery cable back up, I get a constant wimby beep, beep, beep from the horn that won't stop until I unhook the battery cable again.
Old 05-25-2009, 07:22 PM   #9
talon90
NCM Ambassador
talon90's Avatar
To me, and reading your description, you likely need a new car battery.
Old 05-25-2009, 07:29 PM   #10
corvettezman
CF Senior Member
You are more than likely describing a dead battery issue.
Old 05-25-2009, 07:41 PM   #11
cclive
CF Senior Member
cclive's Avatar
Put jumper cables on it with the other car running and I'll bet all this goes away...
Old 05-25-2009, 07:46 PM   #12
*FAÇADE*
CF Senior Member
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
*FAÇADE*'s Avatar
Sounds like it might be time for a new battery!
*FAÇADE* is offline   Reply With Quote
Old 05-25-2009, 08:59 PM   #13
danl72
CF Senior Member
danl72's Avatar
Send a message via Yahoo to danl72
danl72 is offline   Reply With Quote
Reload this Page Corvette won't start, but battery OK !
Tags
113, 2005, battery, beeping, cables, corvette, horn, jumper, problems, sounds, start, starting, stop, vette, volts
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
I'm having a problem with my battery going dead, gauges causing it? BlackMagicC5 C5 Forced Induction/Nitrous 16 02-16-2005 11:33 AM
West Coast Corvette Challenge...2003 Event #3 Results & a Few Pics...3/29/03 Blue85L98 Drag Racing 19 04-01-2003 11:39 PM
HELP: Garaged 93 Corvette won't start dizwiz24 C4 Tech/Performance 12 01-02-2002 08:42 PM
Just got my first Corvette and I already need help Drache C3 Tech/Performance 24 09-11-2001 10:41 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
