Skip Shift Bypass
Old 05-15-2009, 04:26 PM
itsjer
itsjer's Avatar
St. Jude Donor '09
Default Skip Shift Bypass
I'm looking for a skip shift bypass and am wondering what you would suggest? I have seen several different types sold by many vendors. I have a 2005 C6 and I don't have a ramp and haven't jacked it up yet. Are the fuses ok?
Old 05-15-2009, 04:39 PM
Uncle Meat
Uncle Meat's Avatar
I went with the harness pigtails for the electrical connection on the tranny. Worked like a charm.
U.M.
Old 05-15-2009, 04:41 PM
dvilin
dvilin's Avatar
Received 7,922 Likes on 4,808 Posts
Check out Southern Car Parts, they have what you want and have a post a few down from yours.
Old 05-15-2009, 04:57 PM
Markallamerican
Markallamerican's Avatar
Blown LED fuse works great for me!
Old 05-15-2009, 05:02 PM
steve m baker
steve m baker's Avatar
I've got a spare skip shift eliminator. Was on an 05 C6. Shoot me a PM with your address and I'll mail it to you, no charge.
Old 05-15-2009, 06:26 PM
Montanajim
Montanajim's Avatar
Go to O'Reilly's, buy a $3 pack of Littel brand 10 amp smart fuses. Use jumper wires from your battery to blow the fuse and install it in place of your CAGS fuse in the fuse box. Check your owner's manual to locate the correct fuse on the diagram. Should do the job for you and eliminate the need to jack up the car. If it doesn't work, you can always pay $20 for a harness hook-up at the solenoid. Or, take the free offer from poster #5...
Old 05-15-2009, 06:59 PM
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
IMO have the skip-shift feature eliminated via tuning. It's clean and easy. In the year or so I drove my car in stock trim, I think the skip-shift feature activated maybe twice. It was a PITA when it activated but with 'normal' driving I don't think it's really much of a bother. That said I'd still eliminate it.
Old 05-15-2009, 07:05 PM
thisismyusername
thisismyusername's Avatar
To the OP... I don't have ramps or a lift either... I just went to a local high school parking lot on the weekend and found a friendly curb that I got the two right wheels up on. It was very tight space, but I was able to get it on. I think I bought my CAGS eliminator from Ecklers.
Old 05-15-2009, 08:26 PM
ByByBMW
ByByBMW's Avatar
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
PM the guy that wants to give you a free one. Best way to go since it costs you nothing and you don't have to tune the car to get rid of it. And yes, the fuses work great.
Old 05-15-2009, 08:31 PM
VET4LES
VET4LES's Avatar
Floor jack and jack stand in the garage and it took ten minuets or less.
Old 05-15-2009, 09:49 PM
RPHCRMZ51
RPHCRMZ51's Avatar
me to !!!
Old 05-15-2009, 09:59 PM
budgreen3564
budgreen3564's Avatar
try this
http://www.corvettemods.com/servlet/Detail?no=36
Old 05-16-2009, 04:03 AM
Uncle Meat
Uncle Meat's Avatar
I just waited until it was time to change the oil and modded the harness then while I had the car in the air.
U.M.
Old 05-16-2009, 04:07 AM
LS WON
LS WON's Avatar
They still have that Skip shift CAGS on 6 spd on C-6 Corvettes? ZR-1 and Z-06 too?
How about two pairs of Rhino ramps behind the front and the rear tires to get C-6 up and level with more space?
Old 05-16-2009, 06:05 AM
Rob 99
I'm "Apache" a psycho dog
Rob 99's Avatar
Yup thats what i use, almost to simple to believe
Old 05-16-2009, 06:46 AM
corvettezman
corvettezman's Avatar
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I went with this as well. They have good customer service and good prices.
I think it's around $20 or so. It takes 20 mins to install if you have a floor jack, including jacking the car up and sliding the jack stand under it for safety. Actual install less than 5 mins.
The harness is on the upper side of the transmission on the driver's side.
Instructions are included with the kit.
Old 05-16-2009, 10:06 AM
z51vett
z51vett's Avatar
The 09 I trade for my Z06 would come on and lock the shifter between gears had to turn Car off and restart to allow solenoid to retract. Will not own a Car without one don't like the Fuse idea.
z51vett
To Skip Shift Bypass
Old 05-18-2009, 01:16 PM
itsjer
itsjer's Avatar
St. Jude Donor '09
Thanks for the comments.
Old 05-18-2009, 01:17 PM
tomiboy
tomiboy's Avatar
Old 05-18-2009, 04:35 PM
biskitman
biskitman's Avatar
install the fuse you can buy for 15-20 dollars. Much easier than crawling under car! Had one for 3 months , no codes or problems yet!
Quick Reply: Skip Shift Bypass
